Are you sure? There are still chances something might be up with the new firmware, we’d like to see if there’s something to fix on our side.
Try installing the Firmware image and the editor from here:
First install the editor, then do the firmware flashing via bootloader. Also (temporarily) disable automatic check for updates in the Help menu before flashing.
