Do LEDs turn on if you start Midihub in its bootloader mode? (keep the button pressed while powering up the Midihub, either by flipping the switch or plugging in the USB cable) In bootloader mode, all of the LEDs are supposed to light up.
If they do, try performing an offline firmware upgrade, as described here:
- Put Midihub in bootloader mode by turning it on while holding down the button. All LEDs will be on in this mode.
- Connect using the latest Editor version (1.15.3 at time of writing).
- Do Device → Flash Firmware…
- Give it the .bfw Firmware file from the latest release (1.15.1 at time of writing).
- Once done, reconnect to Midihub, it should be running the flashed Firmware with blank memory.
