Midihub output problem
Just received the midihub a couple days ago, thanks for the quick process and shipping. I am using a Keystep and blofeld with simple two pipe input/output Midi channel A, no modifiers. The led A on the midihub flashes when the Keystep is used so I know there is input. I also see output through usb in my midiOx output monitor. But no sound from the blofeld which is on midi channel 1 and works ok connected by midi directly to the keystep. So feeling silly at this point what I am overlooking.
thanks
G
I updated with the new firmware and ensured the device was connected to the editor, works ok now.
Most likely you weren’t connected to the device originally. Good to hear it’s working now! :slight_smile:
