Hello, Midihub has just arrived, but I have some problems … I connected keystep to midihub input port A, the midihub out port is connected to the Octatrack in port. Now, when pipes are not set, the signal passes smoothly, but as soon as I put, for example, an arpeggiator, the midi signal stops working. Same thing in Ableton live. I guess I don’t understand any options, I guess it’s some settings, on my part wrong, but I can’t understand what I’m doing wrong. Any help? Thanks!
Arpeggiator needs a clock, otherwise no signal plays.
Check this out: Arpeggiator not work
Oh!Really?I thinked, wrongly, that the keystep send out the midi clock. Really simple!Many thanks!I’ll try tomorrow!
many thanks!I’ll check for sure!
Probably you can get it to work with Beatstep Pro producing the clock. As long as there’s MIDI clock flowing through the Arpeggiator pipe, it will work.
Oh, nice tip!Thanks, I have a Beatstep pro too
