I have a small setup of four hardware units and my computer. I run Logic Pro for my daw. The issue Im having is Im not sure how to setup my sequencer on my hardware to Logic through the midi hub. Do I need to do anything in the audio “midi setup first”?
The main thing I would like to get going first is my Toraiz Sp16 sampler/sequencer. I would like to sync it so when I push play in my daw it will play the sequencer. Also Im not sure what settings to use on the sp16 itself because there’s a lot of settings to choose from for how it responds to midi.
Eventually I would like to set up this behavior for my micro freak and organelle as well, but I want to set this up first. As Of right now, I have the toraiz sp16 in midi port A and the usb of the Midihub connected to the computer. My interface is a motu m4 but Im not using the midi ports if that makes a difference.
Anyone mind helping me get this setup. I need basic Midihub setup help as well as logic midi setup I think. I’ve only ever really used midi with just hardware. Thanks
