Pls help me with my
MPC 1 to Logic Pro to MIDI HUB TO NDLR TO ROLLAND HAND SONIC SPD 10
If I can be connected to MIDI HUB
also the software idea behind the hub to operate .
My email is
Kghatamkumar@gmail.com
Pls help me with midi hub setting up or zoom meeting or messenger Facebook @ MANOHAR GURUNG
Hi, I’d recommend to first start simple and get some simple communication between minimal amount of devices going, like your PC, Midihub and MPC 1.
Have you tried setting something up already? How far did you get?
What in particular are you trying to achieve?
The solution to your setup depends a lot on what you want it to do.
Not yet I need help pls guide me
Manohar Gurung
Hi, first try doing something simple, like connecting your PC to one of your devices through MIDI cables. To do that:
- Connect to Midihub using the editor
- File → Open Example
- Pick
MIDI USB interface.mhp - Device → Store → Preset 1
After this, the Preset 1 will contain a very basic USB MIDI host preset, with no effects or custom routings. You should be able to get your DAW to communicate via Midihub with the connected device, and send MIDI data.
Once you get any data through, you may try familiarize yourself with some of the processing pipes Midihub has by placing it in the appropriate locations. For example, if you’re using FROM USB A to MIDI A, you should put something, like a Delay pipe into that horizontal pipeline to add delay effect.
Btw, some other users struggled getting MIDI Data out of Logic Pro, I haven’t used it, but maybe this discussion will be helpful: Trouble integrating into Logic Pro X setup
Please ask us any questions you have in the process, so we can know how to help you best to get started.
Thanks
Manohar Gurung
I did a little bit of parches but could not figure out
Could you attach the current preset you have, and describe what you are trying to achieve in your setup? Start from something simple, like get MIDI from a keyboard, to some audio producing device. Once you get basic data flowing, it’s easier to add complexity and more routings & processing.
I did simple Daisy chain with proxi MIDI controller
But in the dreadbox TYPHON only one preset seems like controlling with the PROXI MIDI.
The other preset of dreadbox TYPHON when Daisy chain with NDLR is not controlled .
Only one preset in the dreadbox TYPHON got the message and I can modulate the dreadbox TYPHON preset sounds
Pls guide me
