Hi! I’m trying to build this plugin for modep (Patchbox 2022-05-17). I’ve tried to launch build.sh from a Debian bullseye 64bit installed on vmware and this is the build log.
I copied the structure of modep-lv2-artyfx but obviously it’s not enough.
Is there any guide about building modep plugins?
dpkg-buildpackage -us -uc -ui -b
dpkg-buildpackage: info: source package modep-lv2-aidadsp
dpkg-buildpackage: info: source version 1.0.0-1
dpkg-buildpackage: info: source distribution buster
dpkg-buildpackage: info: source changed by Giedrius Trainavičius <giedrius@blokas.io>
dpkg-source --before-build .
dpkg-buildpackage: info: host architecture amd64
fakeroot debian/rules clean
dh clean
dh_clean
debian/rules build
dh build
dh_update_autotools_config
dh_autoreconf
debian/rules override_dh_auto_configure
make[1]: Entering directory '/home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0'
dh_auto_configure -- -DCMAKE_INSTALL_PREFIX=/usr/modep/lv2 -DBUILD_GUI=OFF -DBUILD_SSE=OFF
cd obj-x86_64-linux-gnu && cmake -DCMAKE_INSTALL_PREFIX=/usr -DCMAKE_BUILD_TYPE=None -DCMAKE_INSTALL_SYSCONFDIR=/etc -DCMAKE_INSTALL_LOCALSTATEDIR=/var -DCMAKE_EXPORT_NO_PACKAGE_REGISTRY=ON -DCMAKE_FIND_PACKAGE_NO_PACKAGE_REGISTRY=ON -DCMAKE_INSTALL_RUNSTATEDIR=/run "-GUnix Makefiles" -DCMAKE_VERBOSE_MAKEFILE=ON -DCMAKE_INSTALL_LIBDIR=lib/x86_64-linux-gnu -DCMAKE_INSTALL_PREFIX=/usr/modep/lv2 -DBUILD_GUI=OFF -DBUILD_SSE=OFF ..
-- The C compiler identification is GNU 10.2.1
-- The CXX compiler identification is GNU 10.2.1
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working C compiler: /usr/bin/cc - skipped
-- Detecting C compile features
-- Detecting C compile features - done
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working CXX compiler: /usr/bin/c++ - skipped
-- Detecting CXX compile features
-- Detecting CXX compile features - done
CMAKE_CXX_FLAGS_RELEASE in aidadsp-lv2 = -O3 -DNDEBUG -fprefetch-loop-arrays -funroll-loops -static-libstdc++ -Wl,-Ofast -Wl,--as-needed -Wl,--strip-all
CMAKE_SHARED_LINKER_FLAGS_RELEASE in aidadsp-lv2 = -static-libstdc++ -Wl,-Ofast -Wl,--as-needed -Wl,--strip-all
RTNEURAL_XSIMD in aidadsp-lv2 = ON
-- RTNeural -- Using xsimd backend
-- Found PkgConfig: /usr/bin/pkg-config (found version "0.29.2")
-- Checking for module 'lv2>=1.10.0'
-- Found lv2, version 1.18.2
-- Configuring done
-- Generating done
CMake Warning:
Manually-specified variables were not used by the project:
BUILD_GUI
BUILD_SSE
-- Build files have been written to: /home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/obj-x86_64-linux-gnu
make[1]: Leaving directory '/home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0'
dh_auto_build
cd obj-x86_64-linux-gnu && make -j2 "INSTALL=install --strip-program=true" VERBOSE=1
make[1]: Entering directory '/home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/obj-x86_64-linux-gnu'
/usr/bin/cmake -S/home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0 -B/home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/obj-x86_64-linux-gnu --check-build-system CMakeFiles/Makefile.cmake 0
/usr/bin/cmake -E cmake_progress_start /home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/obj-x86_64-linux-gnu/CMakeFiles /home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/obj-x86_64-linux-gnu//CMakeFiles/progress.marks
make -f CMakeFiles/Makefile2 all
make[2]: Entering directory '/home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/obj-x86_64-linux-gnu'
make -f rt-neural-generic/RTNeural/RTNeural/CMakeFiles/RTNeural.dir/build.make rt-neural-generic/RTNeural/RTNeural/CMakeFiles/RTNeural.dir/depend
make[3]: Entering directory '/home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/obj-x86_64-linux-gnu'
cd /home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/obj-x86_64-linux-gnu && /usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0 /home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/modules/RTNeural/RTNeural /home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/obj-x86_64-linux-gnu /home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/obj-x86_64-linux-gnu/rt-neural-generic/RTNeural/RTNeural /home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/obj-x86_64-linux-gnu/rt-neural-generic/RTNeural/RTNeural/CMakeFiles/RTNeural.dir/DependInfo.cmake --color=
Dependee "/home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/obj-x86_64-linux-gnu/rt-neural-generic/RTNeural/RTNeural/CMakeFiles/RTNeural.dir/DependInfo.cmake" is newer than depender "/home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/obj-x86_64-linux-gnu/rt-neural-generic/RTNeural/RTNeural/CMakeFiles/RTNeural.dir/depend.internal".
Dependee "/home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/obj-x86_64-linux-gnu/rt-neural-generic/RTNeural/RTNeural/CMakeFiles/CMakeDirectoryInformation.cmake" is newer than depender "/home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/obj-x86_64-linux-gnu/rt-neural-generic/RTNeural/RTNeural/CMakeFiles/RTNeural.dir/depend.internal".
Scanning dependencies of target RTNeural
make[3]: Leaving directory '/home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/obj-x86_64-linux-gnu'
make -f rt-neural-generic/RTNeural/RTNeural/CMakeFiles/RTNeural.dir/build.make rt-neural-generic/RTNeural/RTNeural/CMakeFiles/RTNeural.dir/build
[ 20%] Building CXX object rt-neural-generic/RTNeural/RTNeural/CMakeFiles/RTNeural.dir/RTNeural.cpp.o
cd /home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/obj-x86_64-linux-gnu/rt-neural-generic/RTNeural/RTNeural && /usr/bin/c++ -DRTNEURAL_DEFAULT_ALIGNMENT=16 -DRTNEURAL_USE_XSIMD=1 -I/home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/modules/RTNeural/RTNeural/../modules/json -I/home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/modules/RTNeural/modules/xsimd/include -g -O2 -ffile-prefix-map=/home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -std=gnu++17 -o CMakeFiles/RTNeural.dir/RTNeural.cpp.o -c /home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/modules/RTNeural/RTNeural/RTNeural.cpp
[ 40%] Linking CXX static library libRTNeural.a
cd /home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/obj-x86_64-linux-gnu/rt-neural-generic/RTNeural/RTNeural && /usr/bin/cmake -P CMakeFiles/RTNeural.dir/cmake_clean_target.cmake
cd /home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/obj-x86_64-linux-gnu/rt-neural-generic/RTNeural/RTNeural && /usr/bin/cmake -E cmake_link_script CMakeFiles/RTNeural.dir/link.txt --verbose=1
/usr/bin/ar qc libRTNeural.a CMakeFiles/RTNeural.dir/RTNeural.cpp.o
/usr/bin/ranlib libRTNeural.a
[ 40%] Built target RTNeural
make -f rt-neural-generic/CMakeFiles/rt-neural-generic.dir/build.make rt-neural-generic/CMakeFiles/rt-neural-generic.dir/depend
cd /home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/obj-x86_64-linux-gnu && /usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0 /home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/rt-neural-generic /home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/obj-x86_64-linux-gnu /home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/obj-x86_64-linux-gnu/rt-neural-generic /home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/obj-x86_64-linux-gnu/rt-neural-generic/CMakeFiles/rt-neural-generic.dir/DependInfo.cmake --color=
Dependee "/home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/obj-x86_64-linux-gnu/rt-neural-generic/CMakeFiles/rt-neural-generic.dir/DependInfo.cmake" is newer than depender "/home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/obj-x86_64-linux-gnu/rt-neural-generic/CMakeFiles/rt-neural-generic.dir/depend.internal".
Dependee "/home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/obj-x86_64-linux-gnu/rt-neural-generic/CMakeFiles/CMakeDirectoryInformation.cmake" is newer than depender "/home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/obj-x86_64-linux-gnu/rt-neural-generic/CMakeFiles/rt-neural-generic.dir/depend.internal".
Scanning dependencies of target rt-neural-generic
make -f rt-neural-generic/CMakeFiles/rt-neural-generic.dir/build.make rt-neural-generic/CMakeFiles/rt-neural-generic.dir/build
[ 60%] Building CXX object rt-neural-generic/CMakeFiles/rt-neural-generic.dir/__/common/Biquad.cpp.o
cd /home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/obj-x86_64-linux-gnu/rt-neural-generic && /usr/bin/c++ -DRTNEURAL_DEFAULT_ALIGNMENT=16 -DRTNEURAL_USE_XSIMD=1 -Drt_neural_generic_EXPORTS -I/home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/rt-neural-generic/rt-neural-generic -I/home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/rt-neural-generic/./src -I/home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/rt-neural-generic/../common -I/home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/rt-neural-generic/../modules/RTNeural/modules/json -I/home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/rt-neural-generic/../modules/RTNeural -I/home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/modules/RTNeural/RTNeural/../modules/json -I/home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/modules/RTNeural/RTNeural/.. -I/home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/modules/RTNeural/modules/xsimd/include -g -O2 -ffile-prefix-map=/home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -std=gnu++17 -o CMakeFiles/rt-neural-generic.dir/__/common/Biquad.cpp.o -c /home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/common/Biquad.cpp
[ 80%] Building CXX object rt-neural-generic/CMakeFiles/rt-neural-generic.dir/src/rt-neural-generic.cpp.o
cd /home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/obj-x86_64-linux-gnu/rt-neural-generic && /usr/bin/c++ -DRTNEURAL_DEFAULT_ALIGNMENT=16 -DRTNEURAL_USE_XSIMD=1 -Drt_neural_generic_EXPORTS -I/home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/rt-neural-generic/rt-neural-generic -I/home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/rt-neural-generic/./src -I/home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/rt-neural-generic/../common -I/home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/rt-neural-generic/../modules/RTNeural/modules/json -I/home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/rt-neural-generic/../modules/RTNeural -I/home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/modules/RTNeural/RTNeural/../modules/json -I/home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/modules/RTNeural/RTNeural/.. -I/home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/modules/RTNeural/modules/xsimd/include -g -O2 -ffile-prefix-map=/home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -std=gnu++17 -o CMakeFiles/rt-neural-generic.dir/src/rt-neural-generic.cpp.o -c /home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/rt-neural-generic/src/rt-neural-generic.cpp
[100%] Linking CXX shared library rt-neural-generic.so
cd /home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/obj-x86_64-linux-gnu/rt-neural-generic && /usr/bin/cmake -E cmake_link_script CMakeFiles/rt-neural-generic.dir/link.txt --verbose=1
/usr/bin/c++ -fPIC -g -O2 -ffile-prefix-map=/home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -Wl,-z,relro -shared -Wl,-soname,rt-neural-generic.so -o rt-neural-generic.so CMakeFiles/rt-neural-generic.dir/src/rt-neural-generic.cpp.o CMakeFiles/rt-neural-generic.dir/__/common/Biquad.cpp.o RTNeural/RTNeural/libRTNeural.a
[100%] Built target rt-neural-generic
make[2]: Leaving directory '/home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/obj-x86_64-linux-gnu'
/usr/bin/cmake -E cmake_progress_start /home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/obj-x86_64-linux-gnu/CMakeFiles 0
make[1]: Leaving directory '/home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/obj-x86_64-linux-gnu'
dh_auto_test
create-stamp debian/debhelper-build-stamp
fakeroot debian/rules binary
dh binary
dh_testroot
dh_prep
debian/rules override_dh_auto_install
dh_auto_install
cd obj-x86_64-linux-gnu && make -j2 install DESTDIR=/home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/debian/modep-lv2-aidadsp AM_UPDATE_INFO_DIR=no "INSTALL=install --strip-program=true"
make[4]: Entering directory '/home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/obj-x86_64-linux-gnu'
make[4]: Leaving directory '/home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/obj-x86_64-linux-gnu'
make[4]: Nothing to be done for 'rt-neural-generic/RTNeural/RTNeural/CMakeFiles/RTNeural.dir/build'.
make[4]: Nothing to be done for 'rt-neural-generic/CMakeFiles/rt-neural-generic.dir/build'.
make -f CMakeFiles/Makefile2 preinstall
make[3]: Nothing to be done for 'preinstall'.
Install the project...
/usr/bin/cmake -P cmake_install.cmake
-- Install configuration: "None"
-- Installing: /home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/debian/modep-lv2-aidadsp/rt-neural-generic.lv2/rt-neural-generic.so
-- Up-to-date: /home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/debian/modep-lv2-aidadsp/rt-neural-generic.lv2
-- Installing: /home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/debian/modep-lv2-aidadsp/rt-neural-generic.lv2/modgui
-- Installing: /home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/debian/modep-lv2-aidadsp/rt-neural-generic.lv2/modgui/switches
-- Installing: /home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/debian/modep-lv2-aidadsp/rt-neural-generic.lv2/modgui/switches/switch-001.png
-- Installing: /home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/debian/modep-lv2-aidadsp/rt-neural-generic.lv2/modgui/utils
-- Installing: /home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/debian/modep-lv2-aidadsp/rt-neural-generic.lv2/modgui/utils/dropdown-arrow-white.png
-- Installing: /home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/debian/modep-lv2-aidadsp/rt-neural-generic.lv2/modgui/thumbnail-rt-neural-generic.png
-- Installing: /home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/debian/modep-lv2-aidadsp/rt-neural-generic.lv2/modgui/screenshot-rt-neural-generic.png
-- Installing: /home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/debian/modep-lv2-aidadsp/rt-neural-generic.lv2/modgui/icon-rt-neural-generic.html
-- Installing: /home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/debian/modep-lv2-aidadsp/rt-neural-generic.lv2/modgui/stylesheet-rt-neural-generic.css
-- Installing: /home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/debian/modep-lv2-aidadsp/rt-neural-generic.lv2/modgui/knobs
-- Installing: /home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/debian/modep-lv2-aidadsp/rt-neural-generic.lv2/modgui/knobs/chicken-head
-- Installing: /home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/debian/modep-lv2-aidadsp/rt-neural-generic.lv2/modgui/knobs/chicken-head/_strip.png
-- Installing: /home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/debian/modep-lv2-aidadsp/rt-neural-generic.lv2/modgui/combos
-- Installing: /home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/debian/modep-lv2-aidadsp/rt-neural-generic.lv2/modgui/combos/model-001
-- Installing: /home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/debian/modep-lv2-aidadsp/rt-neural-generic.lv2/modgui/combos/model-001/model-0550.png
-- Installing: /home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/debian/modep-lv2-aidadsp/rt-neural-generic.lv2/modgui.ttl
-- Installing: /home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/debian/modep-lv2-aidadsp/rt-neural-generic.lv2/rt-neural-generic.ttl
-- Installing: /home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/debian/modep-lv2-aidadsp/rt-neural-generic.lv2/manifest.ttl
-- Installing: /home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/debian/modep-lv2-aidadsp/rt-neural-generic.lv2/models
-- Installing: /home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/debian/modep-lv2-aidadsp/rt-neural-generic.lv2/models/README.md
-- Installing: /home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/debian/modep-lv2-aidadsp/rt-neural-generic.lv2/models/Vintage
-- Installing: /home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/debian/modep-lv2-aidadsp/rt-neural-generic.lv2/models/Vintage/VintageRockRythmA.json
-- Installing: /home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/debian/modep-lv2-aidadsp/rt-neural-generic.lv2/models/Vintage/VintageEdgeOfBreakupA.json
-- Installing: /home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/debian/modep-lv2-aidadsp/rt-neural-generic.lv2/models/Moon
-- Installing: /home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/debian/modep-lv2-aidadsp/rt-neural-generic.lv2/models/Moon/MoonCrunchA.json
-- Installing: /home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/debian/modep-lv2-aidadsp/rt-neural-generic.lv2/models/Moon/MoonAcousticA.json
-- Installing: /home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/debian/modep-lv2-aidadsp/rt-neural-generic.lv2/models/Moon/MoonJazzA.json
-- Installing: /home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/debian/modep-lv2-aidadsp/rt-neural-generic.lv2/models/Moon/MoonSeleniumIntroA.json
mv /home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/debian/modep-lv2-aidadsp/usr/modep/lv2/lib/lv2/* /home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/debian/modep-lv2-aidadsp/usr/modep/lv2
mv: cannot stat '/home/user/blokas/modep-debs/modep-lv2-aidadsp/modep-lv2-aidadsp-1.0.0/debian/modep-lv2-aidadsp/usr/modep/lv2/lib/lv2/*': No such file or directory
make[1]: *** [debian/rules:16: override_dh_auto_install] Error 1
make: *** [debian/rules:9: binary] Error 2
dpkg-buildpackage: error: fakeroot debian/rules binary subprocess returned exit status 2
