Hi there,
Cannot find any info about “libhylia”.
What I have done:
git clone https://github.com/BlokasLabs/modep-debs.git --recursive
cd modep-debs
./install-apt-build-dependencies.sh
cd modep-mod-host
./build-deb.sh
Output:
dpkg-buildpackage -us -uc -ui -b
dpkg-buildpackage: info: source package modep-mod-host
dpkg-buildpackage: info: source version 1.8.0-2
dpkg-buildpackage: info: source distribution buster
dpkg-buildpackage: info: source changed by Giedrius Trainavičius hello@blokas.io
dpkg-source --before-build .
dpkg-buildpackage: info: host architecture i386
dpkg-checkbuilddeps: error: Unmet build dependencies: libhylia
dpkg-buildpackage: warning: build dependencies/conflicts unsatisfied; aborting
dpkg-buildpackage: warning: (Use -d flag to override.)
debuild: fatal error at line 1182:
dpkg-buildpackage -us -uc -ui -b failed
Any help appreciated.
It’s this: https://github.com/BlokasLabs/modep-debs/tree/master/libhylia
Looks like you have to build this manually first and install on the device you’re using to build.
Thanks for pointing. It has been successfully built mannualy:
W: libhylia: pkg-config-unavailable-for-cross-compilation usr/lib/pkgconfig/hylia.pc
W: libhylia: pkg-config-references-unknown-shared-library usr/lib/pkgconfig/hylia.pc -lstdc++ (line 9)
Finished running lintian.
But that doesn’t help to build the host:
sudo ./build-deb.sh
dpkg-buildpackage: info: source changed by Giedrius Trainavičius <hello@blokas.io>
Try running all of the build scripts on Raspberry Pi itself, that’s how we built it.
I have no an RPI, just wanted to try out Modep because I had the good experience using Guitarix.
Also tried to build it using -d flag to override:
cc1: some warnings being treated as errors
make[1]: *** [Makefile:97: src/effects.o] Error 1
make[1]: Leaving directory '/home/slavikator/modep-debs/modep-mod-host/modep-mod-host-1.8.0'
dh_auto_build: make -j4 "INSTALL=install --strip-program=true" returned exit code 2
make: *** [debian/rules:9: build] Error 2
dpkg-buildpackage: error: debian/rules build subprocess returned exit status 2
dpkg-buildpackage -us -uc -ui -b -d failed
Probably the real error is somewhere above what you pasted.
Here is everything after sudo ./build-deb.sh:
Summary
debian/rules clean
dh clean
dh_auto_clean
make -j4 clean
make[1]: Entering directory '/home/slavikator/modep-debs/modep-mod-host/modep-mod-host-1.8.0'
dh_clean
debian/rules build
dh build
dh_update_autotools_config
dh_autoreconf
dh_auto_configure
dh_auto_build
cc -I/usr/include/lilv-0 -I/usr/include/sratom-0 -I/usr/include/sord-0 -I/usr/include/serd-0 -DHAVE_FFTW335 -DHAVE_NEW_LILV -DHAVE_JACK2 -g -O2 -fdebug-prefix-map=/home/slavikator/modep-debs/modep-mod-host/modep-mod-host-1.8.0=. -fstack-protector-strong -Wformat -Werror=format-security -O3 -Wall -Wextra -c -std=gnu99 -fPIC -D_GNU_SOURCE -pthread -Wno-deprecated-declarations -Werror=implicit-function-declaration -Werror=return-type -fvisibility=hidden -o src/mod-monitor.o src/monitor/monitor-client.c
cc -I/usr/include/lilv-0 -I/usr/include/sratom-0 -I/usr/include/sord-0 -I/usr/include/serd-0 -DHAVE_FFTW335 -DHAVE_NEW_LILV -DHAVE_JACK2 -g -O2 -fdebug-prefix-map=/home/slavikator/modep-debs/modep-mod-host/modep-mod-host-1.8.0=. -fstack-protector-strong -Wformat -Werror=format-security -O3 -Wall -Wextra -c -std=gnu99 -fPIC -D_GNU_SOURCE -pthread -Wno-deprecated-declarations -Werror=implicit-function-declaration -Werror=return-type -fvisibility=hidden -o src/socket.o src/socket.c
cc -I/usr/include/lilv-0 -I/usr/include/sratom-0 -I/usr/include/sord-0 -I/usr/include/serd-0 -DHAVE_FFTW335 -DHAVE_NEW_LILV -DHAVE_JACK2 -g -O2 -fdebug-prefix-map=/home/slavikator/modep-debs/modep-mod-host/modep-mod-host-1.8.0=. -fstack-protector-strong -Wformat -Werror=format-security -O3 -Wall -Wextra -c -std=gnu99 -fPIC -D_GNU_SOURCE -pthread -Wno-deprecated-declarations -Werror=implicit-function-declaration -Werror=return-type -fvisibility=hidden -o src/uridmap.o src/uridmap.c
cc -I/usr/include/lilv-0 -I/usr/include/sratom-0 -I/usr/include/sord-0 -I/usr/include/serd-0 -DHAVE_FFTW335 -DHAVE_NEW_LILV -DHAVE_JACK2 -g -O2 -fdebug-prefix-map=/home/slavikator/modep-debs/modep-mod-host/modep-mod-host-1.8.0=. -fstack-protector-strong -Wformat -Werror=format-security -O3 -Wall -Wextra -c -std=gnu99 -fPIC -D_GNU_SOURCE -pthread -Wno-deprecated-declarations -Werror=implicit-function-declaration -Werror=return-type -fvisibility=hidden -o src/mod-host.o src/mod-host.c
cc -I/usr/include/lilv-0 -I/usr/include/sratom-0 -I/usr/include/sord-0 -I/usr/include/serd-0 -DHAVE_FFTW335 -DHAVE_NEW_LILV -DHAVE_JACK2 -g -O2 -fdebug-prefix-map=/home/slavikator/modep-debs/modep-mod-host/modep-mod-host-1.8.0=. -fstack-protector-strong -Wformat -Werror=format-security -O3 -Wall -Wextra -c -std=gnu99 -fPIC -D_GNU_SOURCE -pthread -Wno-deprecated-declarations -Werror=implicit-function-declaration -Werror=return-type -fvisibility=hidden -o src/protocol.o src/protocol.c
cc -I/usr/include/lilv-0 -I/usr/include/sratom-0 -I/usr/include/sord-0 -I/usr/include/serd-0 -DHAVE_FFTW335 -DHAVE_NEW_LILV -DHAVE_JACK2 -g -O2 -fdebug-prefix-map=/home/slavikator/modep-debs/modep-mod-host/modep-mod-host-1.8.0=. -fstack-protector-strong -Wformat -Werror=format-security -O3 -Wall -Wextra -c -std=gnu99 -fPIC -D_GNU_SOURCE -pthread -Wno-deprecated-declarations -Werror=implicit-function-declaration -Werror=return-type -fvisibility=hidden -o src/effects.o src/effects.c
cc -I/usr/include/lilv-0 -I/usr/include/sratom-0 -I/usr/include/sord-0 -I/usr/include/serd-0 -DHAVE_FFTW335 -DHAVE_NEW_LILV -DHAVE_JACK2 -g -O2 -fdebug-prefix-map=/home/slavikator/modep-debs/modep-mod-host/modep-mod-host-1.8.0=. -fstack-protector-strong -Wformat -Werror=format-security -O3 -Wall -Wextra -c -std=gnu99 -fPIC -D_GNU_SOURCE -pthread -Wno-deprecated-declarations -Werror=implicit-function-declaration -Werror=return-type -fvisibility=hidden -o src/filter.o src/filter.c
cc -I/usr/include/lilv-0 -I/usr/include/sratom-0 -I/usr/include/sord-0 -I/usr/include/serd-0 -DHAVE_FFTW335 -DHAVE_NEW_LILV -DHAVE_JACK2 -g -O2 -fdebug-prefix-map=/home/slavikator/modep-debs/modep-mod-host/modep-mod-host-1.8.0=. -fstack-protector-strong -Wformat -Werror=format-security -O3 -Wall -Wextra -c -std=gnu99 -fPIC -D_GNU_SOURCE -pthread -Wno-deprecated-declarations -Werror=implicit-function-declaration -Werror=return-type -fvisibility=hidden -o src/completer.o src/completer.c
src/effects.c: In function ‘JackThreadInit’:
src/effects.c:1918:17: error: implicit declaration of function ‘__builtin_ia32_stmxcsr’; did you mean ‘__builtin_ia32_rdtsc’? [-Werror=implicit-function-declaration]
mxcsr = __builtin_ia32_stmxcsr();
src/effects.c:1919:9: error: implicit declaration of function ‘__builtin_ia32_ldmxcsr’; did you mean ‘__builtin_ia32_rdtsc’? [-Werror=implicit-function-declaration]
__builtin_ia32_ldmxcsr(mxcsr | 0x8040);
cc -I/usr/include/lilv-0 -I/usr/include/sratom-0 -I/usr/include/sord-0 -I/usr/include/serd-0 -DHAVE_FFTW335 -DHAVE_NEW_LILV -DHAVE_JACK2 -g -O2 -fdebug-prefix-map=/home/slavikator/modep-debs/modep-mod-host/modep-mod-host-1.8.0=. -fstack-protector-strong -Wformat -Werror=format-security -O3 -Wall -Wextra -c -std=gnu99 -fPIC -D_GNU_SOURCE -pthread -Wno-deprecated-declarations -Werror=implicit-function-declaration -Werror=return-type -fvisibility=hidden -o src/lv2_evbuf.o src/lv2_evbuf.c
cc -I/usr/include/lilv-0 -I/usr/include/sratom-0 -I/usr/include/sord-0 -I/usr/include/serd-0 -DHAVE_FFTW335 -DHAVE_NEW_LILV -DHAVE_JACK2 -g -O2 -fdebug-prefix-map=/home/slavikator/modep-debs/modep-mod-host/modep-mod-host-1.8.0=. -fstack-protector-strong -Wformat -Werror=format-security -O3 -Wall -Wextra -c -std=gnu99 -fPIC -D_GNU_SOURCE -pthread -Wno-deprecated-declarations -Werror=implicit-function-declaration -Werror=return-type -fvisibility=hidden -o src/monitor.o src/monitor.c
cc -I/usr/include/lilv-0 -I/usr/include/sratom-0 -I/usr/include/sord-0 -I/usr/include/serd-0 -DHAVE_FFTW335 -DHAVE_NEW_LILV -DHAVE_JACK2 -g -O2 -fdebug-prefix-map=/home/slavikator/modep-debs/modep-mod-host/modep-mod-host-1.8.0=. -fstack-protector-strong -Wformat -Werror=format-security -O3 -Wall -Wextra -c -std=gnu99 -fPIC -D_GNU_SOURCE -pthread -Wno-deprecated-declarations -Werror=implicit-function-declaration -Werror=return-type -fvisibility=hidden -o src/worker.o src/worker.c
cc -I/usr/include/lilv-0 -I/usr/include/sratom-0 -I/usr/include/sord-0 -I/usr/include/serd-0 -DHAVE_FFTW335 -DHAVE_NEW_LILV -DHAVE_JACK2 -g -O2 -fdebug-prefix-map=/home/slavikator/modep-debs/modep-mod-host/modep-mod-host-1.8.0=. -fstack-protector-strong -Wformat -Werror=format-security -O3 -Wall -Wextra -c -std=gnu99 -fPIC -D_GNU_SOURCE -pthread -Wno-deprecated-declarations -Werror=implicit-function-declaration -Werror=return-type -fvisibility=hidden -o src/symap.o src/symap.c
cc -I/usr/include/lilv-0 -I/usr/include/sratom-0 -I/usr/include/sord-0 -I/usr/include/serd-0 -DHAVE_FFTW335 -DHAVE_NEW_LILV -DHAVE_JACK2 -g -O2 -fdebug-prefix-map=/home/slavikator/modep-debs/modep-mod-host/modep-mod-host-1.8.0=. -fstack-protector-strong -Wformat -Werror=format-security -O3 -Wall -Wextra -c -std=gnu99 -fPIC -D_GNU_SOURCE -pthread -Wno-deprecated-declarations -Werror=implicit-function-declaration -Werror=return-type -fvisibility=hidden -o src/utils.o src/utils.c
cc -I/usr/include/lilv-0 -I/usr/include/sratom-0 -I/usr/include/sord-0 -I/usr/include/serd-0 -DHAVE_FFTW335 -DHAVE_NEW_LILV -DHAVE_JACK2 -g -O2 -fdebug-prefix-map=/home/slavikator/modep-debs/modep-mod-host/modep-mod-host-1.8.0=. -fstack-protector-strong -Wformat -Werror=format-security -O3 -Wall -Wextra -c -std=gnu99 -fPIC -D_GNU_SOURCE -pthread -Wno-deprecated-declarations -Werror=implicit-function-declaration -Werror=return-type -fvisibility=hidden -o src/sha1/sha1.o src/sha1/sha1.c
cc -I/usr/include/lilv-0 -I/usr/include/sratom-0 -I/usr/include/sord-0 -I/usr/include/serd-0 -DHAVE_FFTW335 -DHAVE_NEW_LILV -DHAVE_JACK2 -g -O2 -fdebug-prefix-map=/home/slavikator/modep-debs/modep-mod-host/modep-mod-host-1.8.0=. -fstack-protector-strong -Wformat -Werror=format-security -O3 -Wall -Wextra -c -std=gnu99 -fPIC -D_GNU_SOURCE -pthread -Wno-deprecated-declarations -Werror=implicit-function-declaration -Werror=return-type -fvisibility=hidden -o src/rtmempool/rtmempool.o src/rtmempool/rtmempool.c
cc src/mod-monitor.o -Wl,-z,relro -Wl,--no-undefined -s -ljack -llilv-0 -ldl -lsratom-0 -lsord-0 -lserd-0 -lreadline -lpthread -lrt -lm -lfftw3 -lfftw3f -lfftw3_threads -lfftw3f_threads -shared -o mod-monitor.so
This is a warning treated as an error in x86 specific code. You either have to fix the code or add -Wno-error flag to compile options or remove -Werror if it’s specified somewhere. On another look, it actually could be missing some #include <…> header which contains declarations of these functions at the top of the source file.
But I won’t take the fun away from you to solve every issue you hit when compiling for x86. You should be able to find information and a solution on nearly every kind of error on the internet. Please only ask here about issues that are specific to MODEP that you can’t absolutely find solutions for on the internet first.
Btw, I’ll also move this discussion to a dedicated topic.
Thx for help. I stop at this point as I see that it will be to much time consuming.
In case if someone else interested, I have tried the same steps on both amd64 and i386 deb systems. Error was the same.
It could be not that bad too. A good opportunity to learn more about the software building process.
1Bit
June 10, 2021, 1:38pm
12
@slavikator
have you managed to move forward with this?
I’m stuck at the same point
and even adding the -d flag doesn’t really help much
here the error I get
Feature record: CXX_FEATURE:0cxx_variadic_templates
dh_auto_configure: cd obj-x86_64-linux-gnu && cmake -DCMAKE_INSTALL_PREFIX=/usr -DCMAKE_BUILD_TYPE=None -DCMAKE_INSTALL_SYSCONFDIR=/etc -DCMAKE_INSTALL_LOCALSTATEDIR=/var -DCMAKE_EXPORT_NO_PACKAGE_REGISTRY=ON -DCMAKE_FIND_PACKAGE_NO_PACKAGE_REGISTRY=ON -DCMAKE_INSTALL_RUNSTATEDIR=/run “-GUnix Makefiles” -DCMAKE_VERBOSE_MAKEFILE=ON -DCMAKE_INSTALL_LIBDIR=lib/x86_64-linux-gnu -DCMAKE_INSTALL_PREFIX=/usr/modep/lv2 -DBUILD_GUI=OFF -DBUILD_SSE=OFF … returned exit code 1
make[1]: *** [debian/rules:12: override_dh_auto_configure] Error 2
make[1]: Leaving directory ‘/root/modep-debs/modep-lv2-artyfx/modep-lv2-artyfx-1.3.0’
if anyone can point us to the right direction would be much appreciated
