Virtual Mapping Techniques
Update 30/8/2025
Now Firmware 1.16 has landed, this tutorial will need updating.
New readers should be aware that:
Some images in Setting Mappings will also need updating so I’ll wait a little while before reviewing the content to see if @Giedrius make tweaks to the interface
Hey everyone.
This is my attempt to collect together techniques I picked up with physical loopbacks, and have adapted to the new world of virtual mappings.
I hope folk find something useful in the entries below
cheers, R
Intro
This topic describes various “techniques” that can be useful with virtual mappings.
The list is not exhaustive.
Please add your own or PM me with suggestions.
Each Demo can be taken as stand-alone; have a quick scan of the notes about patches which explains the common structure
Contents
That's as far as I've got right now...
…other sections to follow as hinted at below.
If anyone else wants to provide content –either that I’ve not yet written or stuff I’ve not thought of– that would be great.
(Add it in a reply or PM me and I’ll insert it in the flow)
I’d really like this to be the go-to resource to help more users realise how useful virtual mappings can be: more shared knowledge leads to a better Midihub world
Setting Mappings
The mapping buttons now have symbols to keep them compact:
MIDI Learn only works when Midihub is connected.
The other three buttons can be used any time (making it possible to write entire patches while disconnected)
When you have a lot of mappings to create, setting each of the four mapping properties by hand can be time-consuming.
Fortunately, the Dialogs are set up so you can effectively Copy & Paste mappings.
Here’s a sequence of examples:
You can set a virtual mapping that’s similar to an ‘external’ mapping
When connected, you can use the M button and turn a knob to MIDI Learn the properties…
(here we’re about to click MIDI Learn on Work with .. Range Low ) :asterisk:
..then use Edit to adjust them
Copying Mappings
An existing mapping can be ‘copied’ to another property:
Click Edit to see the existing mapping…
…and just click OK to ‘copy’ it…
…Now when you click Add on another property…
…those same values are now ready to assign to that ‘new location’…
(In this example both ‘Range High’ and ‘Range Low’ are mapped to the same message)
…or modify before assigning:
(In this example, the ‘Range Low’ property of the next pipe is now mapped to CC98)
With a little planning ahead it becomes easy to assign a whole bunch of mappings quite quickly.
(This is particularly true with virtual mappings: because we often can choose which CC#s, etc to use, we can make similar assignments only 1 or 2 small changes apart)
:asterisk: On some OS’s (Win? Linux?) the selected button has a helpful red border all the while the dialogs are open. On Mac OS X you just have to remember. I dunno if @Giedrius can fix this; in the meantime Mac users get extra practice with the UnMap button..
The Demo Patches
Although explanations and pictures might be useful, seeing pipes and pipelines in action is the best way to learn Midihub.
To help show each of the “techniques” below, I’ve written a brief patch/preset to illustrate the idea.
Each patch is written to be standalone:
  • You can use your own keyboard/controller if you want…
    (there are MIDI & USB “Input Lines” for that)
    …but there’s no immediate need.
  • That’s because every patch has a Midihub LFO generating messages for us:
    (the “Generator Line(s)” )
  • These messages then make the mappings:
    (the “Mapping Line(s)” )
  • Then the mappings make changes to certain key pipes:
    (the “Demo Line(s)” )
    • sometimes the effects will be visible without even inspecting the mapped pipe – for example a Bypass getting toggled or an Input/Output changing its Source/Destination
    • in other examples, a key property like Transpose can be inspected, or an LFO or Equalizer graph can be watched.
So each demo patch will follow this pattern:
Note that I will often make no attempt to give the mapped pipes an output.
That’s because the demos are only there to show a technique and leave it you to adapt it for real use.
Trying out a technique
Unless the new capabilities a technique opens up are really obvious, I’d urge users to play around with the demo patch:
  • use MIDI Monitor on pipes in the mapping line to see how the mapping is created
  • change, say, a Rescale so the mapped options change (eg. reverse its High/Low)
    (eventually, why not even map the Rescale options themselves?)
  • try hooking a mapping up to an external device’s parameter so you can hear the effect
  • Sometimes, there might be an extra demo patch to spark the imagination with extra ideas.
    Again, very grateful for additions from other users. I’ll add them to the relevant entry.
back to contents
“Scaled” mappings
Before Virtual Mappings, many users pined for the ability to limit or scale the range of incoming messages for a mapping:
so if a control sends in values in a [0,127] range, we might want the effect on a mapped property to be only in the range [0, 32]
Virtual Mappings allow us to use Rescale to modify the incoming messages before they
reach a virtual port and can be used as a mapping.
This Demo
VM1_rescaled_mappings.mhp
There are 3 Rescale pipes creating 3 mappings:
  1. CC#3 is Rescaled from 72 → 119;
    this changes the Input Pipe Source from Virtual A → Virtual G
  2. CC#4 is Rescaled from 52 → 76;
    this is used to restrict Transpose to ±12 semitones
  3. Note 24 (low C) Bypasses MIDI D OUT when the velocity is low
Extra
VM1a_rescaled_extra.mhp
This patch shows the effect of more than one synced CCs on, say, LFO or Equalizer
back to contents
“Scale Down → Scale Up” mappings
Using Rescale to ‘squeeze’ the 0 → 127 range to a small number of values, then another Rescale to ‘stretch’ them is a good way to make a few ‘spaced out’ values
This Demo
VM2_double_scaled_mappings.mhp
  1. A Transpose pipe mapped to jump in octaves
  2. A Delay pipe with Time Division mapped to only give the dotted times (1/16• → 1/2•)
Notes:
  • as two mapping lines are used here for clarity, each has a CC Range Filter to prevent unscaled mappings reaching the same virtual out of the other line.
    This can avoided with just one mapping line obviously, or by using different virtual outputs, if you’re not already running short!
  • Rescaling down to a small number (3 → 20 ish) leaves a noticeably smaller range for the highest and lowest values. I compensated for this by clipping the In Ranges of “Scale Down” Rescales.
:thought_balloon: getting a “double rescale” right can take a little tweaking. Should have we an explainer for Rescale/Remap?
back to contents
“Toggled State” mappings
Another popular request answered by virtual mappings: a toggle switch that alternates with successive key presses.
Here the mapping line is mapped to itself: the value stored is Argument 1 of a Transform pipe is flipped by the Rescale at the end of the pipeline. This “reversed” value is then mapped back the Argument itself, changing it ready for the next key-press.
This Demo
VM3_toggle_switches.mhp
Many “switch” Transforms can be placed in the same mapping line.
This Demo uses 3 switches (but you can add as many as you like)- each controls a Bypass in the demo line.
One Button CC version (no Generator Lines)
Here’s a two line preset showing just a CC10 being used to switch an input On & Off
VM3.1_Single_CC_Toggle.mhp
These diagrams show the message flow…
..when the CC10 button is pressed…
…and then pressed again…
(Check this with the MIDI Monitor at various pipes)
back to contents
“Cycled State” mappings
A toggle state cycles between just two values. This demo show one way of cycling between up to 16 values by using Dispatcher
This Demo
VM4_cycled_mappings.mhp
The Demo line source will cycle between certain inputs dictated by the Dispatcher channels selected.
Notes:
  1. Whereas a “Scale Down → Scale Up” mapping will allow output values like 16, 24, 40, 48, 56, 64, this technique goes through the values in (‘Round Robin’) order
    and allows us to skip values to give, say, 16, 24, 56, 64
  2. This Dispatcher is set to the original ‘Round Robin’ Algorithm to ascend the values and then cycle back to the lowest.
    Setting to ‘Ping Pong’ or ‘Random’ will give quite different results which may also be useful or interesting.
  3. The key Transform uses Set Value to Incoming Channel. This produces values 0, 8, 16, 24,…
    A Rescale is included to change this to whatever mapping is suitable.
Other techniques which can give similar results include:
  • Multiple “Range” mappings.
    A pipe per value approach.
    More flexible, can be any length/spacing, more laborious to write and adapt
  • Scale Remap approaches.
    Limited to 12 values initially.
    Very useful when you need a custom route through a set of values
    (This is detailed below & an example can be found here)
Scale Remap cycles
The Dispatcher technique above allows a single key/button to run through an ascending sequence –perhaps with gaps– with up to 16 elements:
0 → 1 → 3 → 6 → 8 → 9 → 12 → 0
This variation allows for a sequence in any order with up to 12 elements:
0 → 6 → 3 → 11 → 10 → 9 → 5 → 0
It uses (misuses?) the Scale Remap pipe’s ability to send any semitone to any semitone..
..and stores the result in the Transform that creates the Remap’s incoming note.
VM4a_ScaleRemap_cycled_mappings.mhp
This animation shows this in action selecting 4 LFO Waveforms:
Saw Up → Tri → Saw Down → PWM → (Saw Up)
LFOcycleUniF
(the Roman numeral interval numbers get a bit confusing – I just ignore them and count from zero!)
Other use examples would be selecting Arpeggiator Note Lengths &/or Arp Types in a particular order.
This approach, like “Toggled State” mappings needs to store its state in a Transform argument
here's the message flow
here the Scale Remapped note has two roles:
  1. to create an scale the mapping state we want for elsewhere in the preset
  2. to map the new note# back to the “creator” Transform so that it is ready for the next external trigger.
NB. The Length pipe is necessary as, otherwise, Scale Remap will not work as expected once it has reached it’s memory limit. We use the Note Off here for mapping 2.
Scale Remap Extras
Intro and Loop sequences
Scale Remap can also be used for a lead in to a cycle eg.
0 → 6 → 3 → (11 → 10 → 5 → ) (11 → 10 → 5 → )…
or even
0 → 6 → 3 → (11 → ) (11 → ) (11 → )…
Multiple sequences
In these cases, it may be useful to use a separate button/key to jump back to the beginning of the sequence.
The approach can also be used for multiple cycles triggered from separate Transform Note On “creators”, each following a (non-coincident) path;
  • say 0 → 6 → 3 → 11 → 10 → 9 → 0
  • and 1 → 4 → 8 → 7 → 10 → 2 → 1
(here the separate “creator” Notes are on different channels so that they can be handled independently after the Scale Remap)
back to contents
“Trigger” mappings
Mappings that only happen when a value threshold is reached
to be continued..
Similar to above – using Transform pipes to select ranges of input values
to be continued..
“Timed Choice” mappings
Using Virtual mappings to distinguish between say a “long press” and a “short press”
to be continued..
“Anonymous” or “Proxy” mappings
Even ‘traditional’ mappings can be made more versatile by substituting virtual mappings.
This perhaps so simple it’s easy to overlook how useful it can be.
Instead of the usual mapping from MIDI-A, USB-C and so on…
…use a virtual mapping
The mapped property behaves exactly the same..
..but now you have the freedom to send the mapping message from wherever you want…
…without having to remap your controls
Why is this useful?
The mapping might be modulated initially from a keyboard or controller on MIDI-A..
..but later you might want to send these same mapping events from..
  • ..a sequencer on MIDI-B
  • ..or a DAW on USB-A
  • ..or even from within Midihub itself
    (showing an LFO here but there are many other possibilities)
“Anonymous” mappings allow us to just add those inputs to the message flow..
..instead of re-designing the mappings or adding extra ones.
And if you decide later you want to change the channel (or some other attribute) of the mapping..
…it’s maybe be easier to just add a “channel translation” Transform to “correct” the incoming channel..
.. particularly when that mapping is used multiple times..
.. or it’s months later and you can’t really remember exactly what you did back then!
Lastly, it might make it easier for folk to adapt your patch if you decide to share it (as discussed here)
(FWIW, nowadays, I use this technique as soon as I go beyond the “quick and dirty” phase of building a preset.)
Demo patch
VM11_anonymous_mappings.mhp
The LFO in the last pipeline has it’s Depth and Phase modulated by CC3 & 4 respectively
  • “Un-Bypass” pipeline 3 and watch the mapped LFO graph move automatically
  • Bypass pipeline 3 and modulate the graph manually from one of the external inputs.
These CCs are “channel corrected” by the two Transforms in pipeline 4 so you can either..
  • ..“break” the mappings by Disabling the Transforms and using a Channel input other than Ch.1
  • … or change the Work with CC Number in Range Low|High value to adjust to the CCs coming from your controller.
04/02/2025 Update
content finally added for “Anonymous” mappings
21/02/2025 Update
content added for “Cycled State” mappings using Scale Remap cycles
LFOcycleUniF
Also, graphic added for “Scale Down → Scale Up” mappings
Update 30/8/2025
