Updating mod-ui in modep
Can anyone point me in the right direction to update mod-ui on a patchbox os install. There’s quite a few new useful features that I’d like to try, but I’m not sure where to clone the repo to. Any help will be appreciated!
Hi, you may put it anywhere you like, just uninstall modep-mod-ui deb package, and most likely the modep-mod-host too. See modep-mod-ui.service and modep-mod-host.service to see how the environment is set up for them to run in.
I have cloned mod-ui and mod-host from moddevices github, but modifying the services doesn’t make it boot. The compile options are ok for mod-host, but mod-ui doesn’t compile, its just a server.py file that runs inside of virtualenv. am I missing something? The is filemanager a cool addition, but I can’t get it to connect either. Need to investigate that further too.
Is there by chance an update to PatchboxOS with updated versions of the software packages?
If so, is there a thread somewhere in this forum with a wishlist for additional packages?
We occasionally update the base Patchbox OS image. Feel free to start a wishlist thread. :slight_smile:
