Orac Remote Client not connecting
I can’t get the Pure Data Client to connect to Orac on my Raspberry Pi with the patchboxOS. I installed MrPeach externals and then I launch the main.pd file and edit the hostname as patchbox and also tried patchbox. The readme file says “note the full stop” Does that mean it needs the period? Anyways I can’t connect either way. So I’m not sure how to get the IP address to put as the hostname. I used the RealVNC address but that did not work and it’s probably wrong. I can hear Orac default patch running in the background by the way. Below are the errors I get.
LISTEN:: listen 6101
warning: 9 removed from poll list but not found
connecting to port 6100
SEND:: connect 10.0.4.25 6100
recv: Connection refused (61)
bad host?
Looks like I had to reboot once Orac was installed and the remote control app started to work.
