Orac remote PD client
Hey all,
I’ve tried a few successful installs of Patchbox and am trying to get the Orac module running in a useful way for a noob like me.
  1. Technobear uses this the remote PD client in his vids to control his Raspi with Orac installed. I’d like to do the same!
    I’ve got my Patchbox Raspi running well, I can connect via BlueTooth App, SSH and VNC (Windows 10) so I know I’ve got the right IP. The screenshot of my remote PD client with the correct IP. Intuitively I wouldn’t expect to be able to connect with just an IP address, and no login credentials, but I can’t seem to find much help out there.
    –or–
  2. Alternately I’d settle for help turning ON the GUI for the PD that auto loads when you boot up the Orac module. hahaha is that WAY easier?
Raspi 4 Model B
pisound
PS can’t wait to make music with this little buddy, thanks for all the work that goes into it.
That looks right actually,
Just to check, I think you need the external ‘mrpeach’ to run this - have you got that already?. ORAC is great, but the documentation is a bit… ‘distributed’ I found :smile:
@thetechnobear has added just the externals it needs to github. Or you can use the ‘help/find externals’ function in Pd.
https://github.com/TheTechnobear/Orac/tree/master/OscClients
Hey, there was an issue introduced recently in the Orac deb packages, please try again after running these commands:
sudo apt update && sudo apt install mec orac
# Just in case restart both services
sudo systemctl restart orac mec
Unfortunately after having a couple goes at this with your suggestions, still can’t connect with the remote PD client. Still open to ideas though!
@soxsa it turned out I didn’t have mrpeach installed, so there’s a step in the right direction.
@Giedrius after running the updates I’ve now got other issues. Looks like Jack routing is pretty messed up, getting dropouts, fuzzy and stuttered playback, seems unrelated to my OG problem.
Sorry to hear that. It’s worth persevering, as ORAC is really good. Have you got ORAC and the MEC services started? Using patchbox-config? If so you should hear his demo1 patch which has a drum machine running and a simple synth on midi channel 1.
On the audio problems, I should leave the the experts here - although if it were me I’d ask what it is you are running when hear that? A Pd patch, or is it the MODEP effects? Then I’d run the ‘top’ command from a terminal window and see what the CPU is doing - if you’re familiar with that. Pressing ‘1’ switches it to show you the load on in the individual cores.
On mine, when I connect using a screen or VNC, then sometimes the ‘pulseaudio’ server starts, which takes CPU and I kill that.
This is a real longshot…but just in case…how are you connecting? I spent some time wrestling with so odd behaviour, only to find that it was caused by connecting using Remote Desktop rather than VNC or screen/keyboard.
Did you run the command exactly as I showed? It should have only updated the ORAC packages which wouldn’t have any impact on the issues you’re facing. Maybe something else changed on the system?
A bit late to the game but another ORAC remote client installation attempt. I have installed PD on another linux box, and added mrpeach externals, which got rid of most of the object create errors on the OscClients/pd/main.pd start up, but I still see a slew of routeOsc errors. Does PD need to be an older version to work with Technobear’s client ? Also looks like Osc handling is moving to the main package… maybe mrpeach can be replaced.
It should run as long as the required externals are there. Please post all the errors you get after opening the client patch.
Looks like routeOsc is missing. I thought it was part of mrpeach, maybe its elsewhere now.
Start up errors:
routeOSC /$1Ctrl
routeOSC /$1Desc
routeOSC /$1Value
routeOSC /$1Ctrl
routeOSC /$1Desc
routeOSC /$1Value
routeOSC /$1Ctrl
routeOSC /$1Desc
routeOSC /$1Value
routeOSC /$1Ctrl
routeOSC /module
routeOSC /page
unpackOSC
packOSC
routeOSC /clearText
routeOSC /text
routeOSC /selectText
Orac client comes with routeOSC, packOSC and unpackOSC externals zipped together with the client patch, however, it includes builds only for Mac x86_64, Windows and ARM32 Linux.
What is the OS you are using?
The object do look like they come from mrpeach external, however, as the Orac client is built around having them batched up together, you may either try copying the particular plugin files from the system’s install in Orac Client’s pd\externals folder, or you have to add an appropriate [declare -path ...] object (or its other variations) or edit the system library search path.
Enabling verbose logs can help nail this down.
I’m on Ubuntu and have no prior experience with PD, so thanks for the guidance. Time to dig in.
Hi tantilla, I hope your doing fine. At this moment I’m struggling with the same issues. Can you please let me know if you got the solution in the end? Thank you very much for your answer!
If you are running on arm64, you have to find the necessary externals, as the ORAC client comes only with prebuilt binaries for arm32.
Hi Giedrius, --SOLVED–sorry for the late reply. I have installed on my Pi v4b the latest Patchbox OS (2024-04-04-Patchbox.zip) it is 64bit oriented as well the Pd itself. After install “oscv0.3(Linux-amd64-64)(Linux-arm64-32)(Linux-arm64-64)(Linux-armv7-32)(Linux-armv7-64)(Linux-i386-32)(Linux-i386-64).dek” file via [Pd - Help - Find externals] these files are in a “osc” folder in [Documents - Pd - externals] just put all the files in the “externals” folder. After start-up Pd there are no errors in Console screen. Hot spot is not working for me but through default WiFi network I also can control remote. At the remote PC you have to install also Pd 64bit -Windows.dek file. Thank you for your help on this!
