Newbie problems
Yes, you have to resolve those messages. Orac client comes with the externals prebuilt for many platforms, unfortunately arm64 externals are missing. If it’s mrpeach that’s missing, try to install it from the APT servers:
sudo apt install pd-mrpeach
Afterwards, you’ll find the externals located at /usr/lib/pd/extra/mrpeach/.
You may try and copy them over under the ORAC client patch and reopen it, or try adding the appopriate [declare …] object into the main patch, one of these should do the trick, or a similar variation, it would be great if you could locate which one is the golden ticket:
