MODEP - Can't Update from 1.13.0-1
I think I reported this previously but I’m still unable to update MODEP from 1.13.0-1 to 1.13.0-2. There is an update notification and clicking on the update I’m prompted to okay upgrading. Clicking Okay spins for a bit and then reloads the pedalboard with the same update available notification.
Hey, what is the output of:
apt show modep-mod-ui
@Giedrius here it is:
Package: modep-mod-ui
Version: 1.13.0-2
Priority: optional
Section: audio
Maintainer: Blokas <hello@blokas.io>
Installed-Size: 9,129 kB
Pre-Depends: modep-common (>= 1.1.0)
Depends: libasound2 (>= 1.0.16), libc6 (>= 2.33), libgcc-s1 (>= 3.0), libjack-jackd2-0 (>= 1.9.10+20150825) | libjack-0.125, liblilv-0-0 (>= 0.22.0~dfsg0), libstdc++6 (>= 11), modep-mod-host (>= 1.13.0-1), modep-mod-midi-merger (>= 0.1.0), modep-browsepy (>= 0.5.7-2), authbind (>= 2.1.2), python3 (>= 3~), python3-aggdraw, python3-pil, python3-pystache, python3-serial, python3-tornado4, python3:any
Homepage: https://blokas.io/modep
Download-Size: 4,361 kB
APT-Manual-Installed: no
APT-Sources: http://apt.blokas.io bookworm/main arm64 Packages
Description: MOD-UI package.
Try running sudo apt install modep-mod-ui, it should upgrade it if it’s not already at 1.13.0-2.
Okay, I did that and also restarted modep-mod-host and modep-mod-ui. I’m still seeing the update available and when I click on the update button on the bottom right I get this:
Clicking OK takes a few seconds and then I get this:
Ah, turns out the published latest version was wrong, fixed it. :slight_smile: It should not ask to update now.
Yep, that did it!
