Because of issues with my Behringer UMC204HD interface that seem to result from an older kernel used by Patchbox OS, I wanted to try my luck by installing Modep on a newer Raspberry Pi OS. However, when following curl https://blokas.io/apt-setup.sh
and sudo apt install modep
Thank you @Griedrius.
I suppose that’s what you get when you know little and try to get by with copying some code from random places…
adding | sh made all the difference, but you knew that already.
I tried Patchbox OS but it didn’t work with my Behringer UMC204HD USN Audio/MIDI interface, unfortunately. I found out that it has to do with the kernel used in Patchbox OS. According to info on the internet, I found that it should work with kernels later than 5.18.xx That’s why I tried installing Raspberry Pi OS. In the latest version the interface works by adding some quircks.
As I don’t know much about it and all troubleshooting is done by searching the internet for days, I would rather have Patchbox OS.
Is there a version coming with a kernel later than 5.18 or is there a beta version I could try?
I have to make up my mind this afternoon because that’s the latest I could return the interface and get my money back. But then the question remains which USB interface does work well with Linux out of the box.
Try sudo rpi-update to get the latest Raspberry Pi kernel build, I think it’s 6.+. Keep in mind that these builds are usually experimental and might be unstable. Normal way is to upgrade “raspberrypi-kernel” APT package, the RPi foundation picks a particular known good version as a stable one and publishes it to everyone through their APT server.
Thanks for the help. I have the kernel updated to 6.1.55 and it worked, for a little while. On reboot it functions as it supposed to do, but after a while I got a very distorted output signal. After reboot same issues.
Since today was the last day that I could return the Behringer and get a refund, I stopped hassling about and sent it back.
Maybe I should go the PiSound route, but I opted for a USB Audio/MIDI interface so I could use it for other things with a PC or laptop as well.
If anybody knows of a simple 2x2 USB Audio interface, preferably with MIDI, that works with Raspberry Pi OS and Patchbox OS/Modep without any hassle, please let met know.
