Can't install MODEP module - apt packages different?
Anyone know of anything going on with the blokas apt repository? I’ve just put patchbox on a new SD card (twice, in case it was a bad flash) and I’m unable to install the modep module via the patchbox cli or directly going sudo apt-get install modep.
Looks like it’s thinking that there’s a mismatch in expected and actual downloaded packages?
As mentioned I’ve re-flashed Patchbox OS in case it was a bad flash, and have tried this with two separate networks - as well as the apt-get clean tricks I’ve found via googling.
Here’s a snippet of the logs
Get:1 http://apt.blokas.io rpi/main armhf modep-common all 1.1.0-1 [2,528 B]
Err:1 http://apt.blokas.io rpi/main armhf modep-common all 1.1.0-1
  File has unexpected size (2524 != 2528). Mirror sync in progress? [IP: 79.98.29.34 80]
  Hashes of expected file:
   - SHA512:2d1b8cf9c929dd4275d5c09469195c625e0f3176b3cca0ca11d689e7df273441ce44e5903eb6f99a553618e49d3e078bb71c1c0bab3300528faebef0b28813e9
   - SHA256:7b026b7190166f55a42f23cebb3f27a96abdfab9fcc57c6fba4e4fb4e6aee798
   - SHA1:d96c8821020499522763072cc0746e53ef3068f2 [weak]
   - MD5Sum:39746a0bbe92d322290ebe1997aa3144 [weak]
   - Filesize:2528 [weak]
Get:2 http://apt.blokas.io rpi/main armhf modep-mod-host armhf 1.13.0-1 [166 kB]
Err:2 http://apt.blokas.io rpi/main armhf modep-mod-host armhf 1.13.0-1
  File has unexpected size (164792 != 166000). Mirror sync in progress? [IP: 79.98.29.34 80]
   - SHA512:a56a2bf668ec6d0b60c7f66fc54580507afcc158c4edba3883fd2b5d12ff395a3240f9a376c9c3fb64cb15a2f244be6700e8ea208c52e18369f23c0418e7a2ee
   - SHA256:c7130dc99115f00c3eaf24497fcd01a58fb0adbc451487eca7b7f70835fcf53f
   - SHA1:4aecc6d631b213f3a4f7dbdd83ae21d44bfcd220 [weak]
   - MD5Sum:888cbb526d959f4d309454786f7f91cf [weak]
   - Filesize:166000 [weak]
Get:3 http://apt.blokas.io rpi/main armhf modep-mod-midi-merger armhf 0.1.0-4 [7,052 B]
Err:3 http://apt.blokas.io rpi/main armhf modep-mod-midi-merger armhf 0.1.0-4
  File has unexpected size (7016 != 7052). Mirror sync in progress? [IP: 79.98.29.34 80]
   - SHA512:a168e9b1004555fb055134ca60492d6af0af41abf21b463b0559c8f3b4d805e093d61bff2136bf8ab439872ef56272bc0fdb39db46896826a587300d96880d82
   - SHA256:e18cc3e2f0fb0a66f2f6ba9027f3253b95692a4efe5ba161106d8fed537832f4
   - SHA1:48e7e9de84e70210391c39da42d57a898cf98d6f [weak]
   - MD5Sum:92d3cfb76c2ed67f9e19d07b133346ec [weak]
   - Filesize:7052 [weak]
Get:4 http://apt.blokas.io rpi/main armhf modep-ctl-scripts all 1.8.0-1 [2,408 B]
Err:4 http://apt.blokas.io rpi/main armhf modep-ctl-scripts all 1.8.0-1
  Hash Sum mismatch
   - SHA512:1143fec8a80dc9d51373b00a980e744c61bbf1d7a38a98f9283672a4e925efc5399c81f182af1a6d687317818a012cd2531ffcc384b80c6368130c3e565a4d50
   - SHA256:5632839553c9f933b853d4b94d2324724e830a2b957adad9130c1dd358bf64c3
   - SHA1:bd6d6e296d82b8b608ad0953a48333b6eaa5fa11 [weak]
   - MD5Sum:4f8e451c805bc144f0fcd353236fd2ea [weak]
   - Filesize:2408 [weak]
  Hashes of received file:
   - SHA512:0a613fa99e91a1f7b8877225bb98d34d9cbaa4ee2b4508825bfc56433ec9dc54733e55b6a435726cf080e0c73a16ed452feac20de2e532f2ad524e63986d501a
   - SHA256:feb18fdbcb9e56418f12ccc2537d1b78ac31af35e74c3f428266745c2fcfdbc6
   - SHA1:454b1f6fb0651aafc954007025375b7c3b38dc3b [weak]
   - MD5Sum:aba3e9158bcbed6de46cf0a17f62009d [weak]
  Last modification reported: Tue, 13 Feb 2024 21:13:57 +0000
Fetched 2,408 B in 1s (4,602 B/s)
E: Failed to fetch http://apt.blokas.io/pool/main/m/modep-common/modep-common_1.1.0-1_all.deb  File has unexpected size (2524 != 2528). Mirror sync in progress? [IP: 79.98.29.34 80]
E: Failed to fetch http://apt.blokas.io/pool/main/m/modep-mod-host/modep-mod-host_1.13.0-1_armhf.deb  File has unexpected size (164792 != 166000). Mirror sync in progress? [IP: 79.98.29.34 80]
E: Failed to fetch http://apt.blokas.io/pool/main/m/modep-mod-midi-merger/modep-mod-midi-merger_0.1.0-4_armhf.deb  File has unexpected size (7016 != 7052). Mirror sync in progress? [IP: 79.98.29.34 80]
E: Failed to fetch http://apt.blokas.io/pool/main/m/modep-ctl-scripts/modep-ctl-scripts_1.8.0.deb  Hash Sum mismatch
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
Please try again. :slight_smile:
That’s done the trick, thanks!
