Is apt.blokas.io unavailable?
I’m trying to setup a PatchboxOS with a Pisound micro. Typing sudo apt install -y pisound-micro-mapper gives:
Reading package lists... Done
The following additional packages will be installed:
  libpisoundmicro
The following NEW packages will be installed:
  libpisoundmicro pisound-micro-mapper
0 upgraded, 2 newly installed, 0 to remove and 441 not upgraded.
Need to get 131 kB of archives.
After this operation, 528 kB of additional disk space will be used.
Ign:1 http://apt.blokas.io bookworm/main arm64 libpisoundmicro arm64 1.0.1-3~bookworm1
Ign:2 http://apt.blokas.io bookworm/main arm64 pisound-micro-mapper arm64 1.0.1-1~bookworm
Err:1 http://apt.blokas.io bookworm/main arm64 libpisoundmicro arm64 1.0.1-3~bookworm1
  Temporary failure resolving 'apt.blokas.io'
Err:2 http://apt.blokas.io bookworm/main arm64 pisound-micro-mapper arm64 1.0.1-1~bookworm
E: Failed to fetch http://apt.blokas.io/pool/main/libp/libpisoundmicro/libpisoundmicro_1.0.1-3%7ebookworm1_arm64.deb  Temporary failure resolving 'apt.blokas.io'
E: Failed to fetch http://apt.blokas.io/pool/main/p/pisound-micro-mapper/pisound-micro-mapper_1.0.1-1%7ebookworm_arm64.deb  Temporary failure resolving 'apt.blokas.io'
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
Is there some issue with your Debian repository?
Seems everything is fine for it on our side - the error you showed seems to be a network / DNS issue, where the ‘apt.blokas.io’ is not getting resolved.
I’m realising it’s a network issue with my Pi. Can’t tell why though. Sorry for the noise!
