Pisound installation failure
Fresh install of 2022-01-28-raspios-bullseye-arm64.zip
root@raspberrypi:~# curl https://blokas.io/pisound/install.sh | sh
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100  1119  100  1119    0     0    201      0  0:00:05  0:00:05 --:--:--   257
Importing Blokas GPG public key...
Warning: apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-key(8)).
OK
Adding Blokas apt repository...
Updating package list...
Hit:1 http://deb.debian.org/debian bullseye InRelease
Get:2 http://deb.debian.org/debian bullseye-updates InRelease [39.4 kB]
Get:3 http://security.debian.org/debian-security bullseye-security InRelease [44.1 kB]
Get:5 http://security.debian.org/debian-security bullseye-security/main armhf Packages [122 kB]
Get:6 http://security.debian.org/debian-security bullseye-security/main arm64 Packages [117 kB]
Get:7 http://security.debian.org/debian-security bullseye-security/main Translation-en [77.0 kB]
Get:4 http://apt.blokas.io rpi InRelease [3,922 B]
Get:8 http://apt.blokas.io rpi/main armhf Packages [40.9 kB]
Get:9 http://archive.raspberrypi.org/debian bullseye InRelease [23.6 kB]
Get:10 http://archive.raspberrypi.org/debian bullseye/main armhf Packages [251 kB]
Get:11 http://archive.raspberrypi.org/debian bullseye/main arm64 Packages [250 kB]
Fetched 970 kB in 6s (152 kB/s)
Reading package lists... Done
N: Skipping acquire of configured file 'main/binary-arm64/Packages' as repository 'http://blokas.io/apt rpi InRelease' doesn't support architecture 'arm64'
Installing Pisound software...
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
 pisound : Depends: pisound-btn (>= 1.13-1) but it is not installable
           Depends: pisound-ctl (>= 1.03-1) but it is not installable
           Depends: blokas-telemetry (>= 1.0.0-1) but it is not installable
E: Unable to correct problems, you have held broken packages.
Updating /usr/local/pisound...
sh: 1: cd: can't cd to /usr/local/pisound
Now you may run sudo pisound-config to customize your installation!
Updating repository reports:
N: Skipping acquire of configured file ‘main/binary-arm64/Packages’ as repository ‘apt.blokas.io rpi InRelease’ doesn’t support architecture ‘arm64’
Do I need to switch to a 32-bit Raspios build?
It worked with 32-bit raspios install, so I assume that answers my question.
