GPG Error on install
pi@sadie:~ $ curl https://blokas.io/pisound/install.sh | sh
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100  2438  100  2438    0     0   4945      0 --:--:-- --:--:-- --:--:--  4945
Checking if the kernel version is  or newer... It is.
Importing Blokas GPG public key...
dd: failed to open '/etc/apt/keyrings/blokas-archive-keyring.gpg': No such file or directory
(23) Failed writing body
Adding Blokas APT rpi repository...
Updating package list...
Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease------
Get:3 http://apt.blokas.io rpi InRelease [3,954 B]------------------
Err:3 http://apt.blokas.io rpi InRelease
  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 37808098F560908A
Reading package lists... Done
W: GPG error: http://apt.blokas.io rpi InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 37808098F560908A
E: The repository 'http://apt.blokas.io rpi InRelease' is not signed.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
Installing Pisound software...
E: Unable to locate package pisound
Updating /usr/local/pisound...
sh: 1: cd: can't cd to /usr/local/pisound
Now you may run 'sudo pisound-config' to customize your installation!
Is this a Bullseye problem or an apt.blokas.io issue with the GPG key?
Thanks!!!
Hey, what output do you get from lsb_release -a?
@Giedrius thanks so much for your quick reply!
No LSB modules are available.
Distributor ID:	Raspbian
Description:	Raspbian GNU/Linux 11 (bullseye)
Release:	11
Codename:	bullseye
For what it’s worth I’m still dealing with this issue: Can't install Pd externals on Raspberry Pi 5
So I am currently using a Raspberry Pi 3B with Pisound because I have ones of that version that work perfectly with my externals. This is a fresh install on a new 3b however.
Please do:
sudo mkdir -p /etc/apt/keyrings
and run the install script again:
Thanks as always that did the trick!!
