Just flashed a new SD with the latest raspbian (04-18-2018) - curl / install not working
Hello,
I just flashed a new version of Raspbian to my SD card (2018-04-18). It’s working fine, but when I try to run the curl command in terminal, I’m seeing the following (copy/paste from terminal):
pi@PiSoundb:~ $ sudo curl https://blokas.io/pisound/install-pisound.sh | sh
% Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                             Dload  Upload   Total   Spent    Left  Speed
100  1146  100  1146    0     0   1562      0 --:--:-- --:--:-- --:--:--  1563
: not found
: not found
: not found
sh: 29: Syntax error: end of file unexpected (expecting "then")
Any idea what I need to do?
edit:
Also, I’ve been trying to download the MODEP torrent; but I’m stuck at 0.0%; any other links I can try?
Hi, thank you for reporting this, I can reproduce the issue too, we’ll get it fixed. :slight_smile:
Great, thanks for the response! Any chance you could start seeding the MODEP image too? I’ve been at 0.0% for hours.
You can download MODEP image directly via http://www.mediafire.com/file/ekfxsw4rwzfsiz7/image_2018-04-03-MODEP.zip
The install-pisound.sh issue was just fixed, running the same command again should work now.
