[Beta] Patchbox OS image 2022-05-17
Updated version available —> here <—
Hey guys! Patchbox OS has been updated to be based on the Bullseye Debian release! It should work just fine with pretty much all the currently released Raspberry Pi’s out there. Also, most of the software that comes installed by default has been updated to latest versions available.
It also includes a real-time kernel installed by default, it’s been verified to run even with Pi 2 and Pi Zero W.
Downloads
  • Direct download
  • SHA-256: 8c806a94daba2298f96ede2a0f3e40f92ce26bf23a4ea357bbaf1919e2f09e4f
Docs
Default Passwords
User name patch
Password blokaslabs
WiFi SSID Patchbox
WiFi password blokaslabs
Please change your user password while going through the wizard, for security. :wink:
The WiFi hotspot is on by default.
for those of us who are rusty at this sort of thing, is there a reasonable way to upgrade in place, or is it better to just back up everything and start with a clean image?
Pi 4 8GB
It’s a little buggy
CPU holds at 100% when using the button - which then fails.
Loading pedalboards is very slow when available
The web gui crashes when connecting with pisound app
I’ll send more details soon with logs
I would generally recommend to start from a clean slate and back up all your custom additions. Not sure it’s strictly necessary, but since it’s based on a completely new debian release version there might be a lot of issues involved.
I’m pretty happy with it so far, but I’m only using it to run my supercollider patches, seems more stable with the xruns, maybe I can even squeeze the latency a bit with the realtime kernel…
best,
dormir
It’s better to backup, flash the new build, and move over your stuff to the new build, that’s the recommended way for Raspberry Pi OS too.
In theory, it’s possible to edit your /etc/apt/sources.list.d/... to point to bullseye and do sudo apt-get dist-upgrade, but that also misses any changes that were done between the OS image releases outside of the deb packages, so in the end, you’d still end up with something different than the newly released image, it’s very complicated to debug and get everything right, as well as it’s not that well tested on Raspberry Pi OS and OSes derived from it, so this should only be attempted by Linux experts that can find their own way through it.
Please provides any steps to reproduce the issue. You can investigate the output of top to see which processes use the most resources.
MODEP didn’t change at all in this release. It used to do this before as well, when I looked into it, it seems the MOD UI isn’t able to handle changes that happen externally well, so you have to simply refresh the page after switching the pedalboard using external mechanisms.
I put it on a spare SD to try it out… I’ll do another flash etc and see what happens, when I get a little more time.
I am having issues installing updates and MODEP. I get the following errors:
1: update errors
E: Repsitory 'http://apt.blokas.io rpi InRelease' changed its 'Origin' value from 'main rpi' to '. rpi'
E: Repsitory 'http://apt.blokas.io rpi InRelease' changed its 'Label' value from 'main rpi' to '. rpi'
N: This must be accepted explicitly before updates for this repository can be applied. See apt-secure(8) manpage for details
  1. Installing MODEP
    Apologies, but I have to transcribe this text manually due to my setup. I won’t do the full stack trace unless it’s really really necessary… but I will try my best
File "/usr/lib/python3/dist-packages/patchbox/module.py", line 621, in _install_module
  raise ModuleError(
patchbox.module.ModuleError: Failed to install modep.module via /usr/local/patchbox-modules/modep/install.sh script
During handling of the above exception, another exception occurred:
File "/usr/bin/patchbox", line 33 in <module>
   sys.exit(load_entry_point('patchbox-cli==1.0', 'console_scripts', 'patchbox')())
(etc)
Does this help debug?
Update: I was able to get past part 1 with sudo apt update which this time asked if I would accept the suggested changes. After that the MODEP module seemed to work.
Was that the solution?
The fix for this is to run the following from the command line:
sudo apt-get update --allow-releaseinfo-change
Now you can go back and run patchbox to install MODEP:
patchbox
Did this happen on the 2022-05-17 image, or are you updating and older install of Patchbox OS?
It happens on the 2022-05-17 image.
Fixed it on our server.
I’m not convinced that it’s fixed. I’ve tried 6 times from a fresh 2022-05-17 image (even a 2020-11-23) with or without an update first (tried --allow-releaseinfo-change and --fix-missing). modep module activation (via patchbox ui or commandline) always results in this error:
Get:51 http://apt.blokas.io rpi/main armhf modep-lv2-zam-plugins armhf 3.12.0-2 [6,399 kB]
Get:52 http://apt.blokas.io rpi/main armhf modep-touchosc2midi armhf 1.0.0-2 [9,360 B]
Fetched 172 MB in 50s (3,422 kB/s) E: Failed to fetch http://apt.blokas.io/pool/main/m/modep-ctl-scripts/modep-ctl-scripts_1.8.0.deb File has unexpected size (2408 != 2432). Mirror sync in progress? [IP: 79.98.29.34 80]
Hashes of expected file:
- SHA512:a02c18f8637356c4153f231ca15d980cf04d4fb6fbd72e77e07703af7ac5238a4bcbdd7766b5b7f01df0ba5588eab1153fc959731b9acec868d73ee69f1f10fd
- SHA256:f8e91f6684c6849f8a2a352632972a2781d9ab558527a54fa892051ce87f78af
- SHA1:3f43ca0d6c854ac4a119a93a1dad104a3f908890 [weak]
- MD5Sum:924c89707d841556aecb545c5b4d2ac8 [weak]
- Filesize:2432 [weak]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
File “/usr/lib/python3/dist-packages/patchbox/module.py”, line 621, in _install_module
raise ModuleError(
Hey guys,
thanks for the update!
Happens to me as well when I try to install modep. I tried sudo apt-get clean and sudo apt-get update --allow-releaseinfo-change, no luck unfortunately. Is the apt mirror out of sync?
I’m on a fresh install of the Beta 2022-05-17.
Tried now to install the orac module. Worked without any issues.
Seems like it’s really a mirror node which is out of sync.
@Giedrius, I saw that it’s possible to install modules from a file. Unfortunately I couldn’t find any information about how to build modep myself and install from a file. Do you know if there is some documentation about it?
MODEP is built using https://github.com/BlokasLabs/modep-debs.
I’ve just fixed the issue with our APT server, the installs should now work again. (if installing manually, make sure to run sudo apt update)
thx mate :slight_smile:
working perfectly now.
Works now for me too. Thanks for the fix @Giedrius!
Although all seems good with the newest Patchbox, it appears that the modep module is not backward compatible with the previous 2020-11-23 version of Patchbox. Maybe that’s expected?
Manager: modep.module install script found: /usr/local/patchbox-modules/modep/install.sh
Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
Hit:2 http://archive.raspberrypi.org/debian buster InRelease
Hit:3 http://apt.blokas.io rpi InRelease
Reading package lists... Done
Building dependency tree
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
 modep : Depends: modep-mod-host (>= 1.8.0-2) but it is not going to be installed
         Depends: modep-mod-ui (>= 1.8.1-1) but it is not going to be installed
         Recommends: modep-fluidsynth (>= 2.1.0-1) but it is not going to be installed
         Recommends: modep-lv2-amsynth (>= 1.9.0-2) but it is not going to be installed
         Recommends: modep-lv2-artyfx (>= 1.3.0-1) but it is not going to be installed
         Recommends: modep-lv2-calf (>= 0.90.3-2) but it is not going to be installed
         Recommends: modep-lv2-caps (>= 0.9.26-1) but it is not going to be installed
         Recommends: modep-lv2-dpf-plugins (>= 1.3.0-1) but it is not going to be installed
         Recommends: modep-lv2-fat1 (>= 0.6.0-1) but it is not going to be installed
         Recommends: modep-lv2-fil4 (>= 0.7.1-1) but it is not going to be installed
         Recommends: modep-lv2-fluidplug (>= 1.0.0-1) but it is not going to be installed
         Recommends: modep-lv2-fomp (>= 1.1.0-1) but it is not going to be installed
         Recommends: modep-lv2-freaked (>= 0.0.1-1) but it is not going to be installed
         Recommends: modep-lv2-guitarix (>= 0.39.0-1) but it is not going to be installed
         Recommends: modep-lv2-gx-slowgear (>= 0.5.0-1) but it is not going to be installed
         Recommends: modep-lv2-gx-switchless-wah (>= 0.1.0-1) but it is not going to be installed
         Recommends: modep-lv2-infamousplugins (>= 0.3.0-1) but it is not going to be installed
         Recommends: modep-lv2-invada-studio (>= 0.0.1-1) but it is not going to be installed
         Recommends: modep-lv2-mda (>= 1.1.0-1) but it is not going to be installed
         Recommends: modep-lv2-midifilter (>= 0.6.2-1) but it is not going to be installed
         Recommends: modep-lv2-mod-distortion (>= 0.0.1-1) but it is not going to be installed
         Recommends: modep-lv2-mod-pitchshifter (>= 0.0.1-1) but it is not going to be installed
         Recommends: modep-lv2-mod-utilities (>= 0.0.1-1) but it is not going to be installed
         Recommends: modep-lv2-mtc (>= 0.2.1-1) but it is not going to be installed
         Recommends: modep-lv2-rkrlv2 (>= 0.3.0-1) but it is not going to be installed
         Recommends: modep-lv2-setbfree (>= 0.8.11-1) but it is not going to be installed
         Recommends: modep-lv2-shiroplugins (>= 0.0.1-1) but it is not going to be installed
         Recommends: modep-lv2-sooperlooper (>= 0.93.0-1) but it is not going to be installed
         Recommends: modep-lv2-tap (>= 1.2.7-1) but it is not going to be installed
         Recommends: modep-lv2-triceratops (>= 0.3.2-1) but it is not going to be installed
         Recommends: modep-lv2-tuna (>= 0.5.2-1) but it is not going to be installed
         Recommends: modep-lv2-zam-plugins (>= 3.12.0-1) but it is not going to be installed
         Recommends: modep-demo-content (>= 1.0.0-1) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
  File "/usr/lib/python3/dist-packages/patchbox/module.py", line 622, in _install_module
    'Failed to install {}.module via {} script'.format(module.name, os.path.join(module.path, module.has_install)))
  File "/usr/bin/patchbox", line 11, in <module>
  File "/usr/lib/python3/dist-packages/click/core.py", line 764, in __call__
    return self.main(*args, **kwargs)
  File "/usr/lib/python3/dist-packages/click/core.py", line 717, in main
    rv = self.invoke(ctx)
  File "/usr/lib/python3/dist-packages/click/core.py", line 1137, in invoke
    return _process_result(sub_ctx.command.invoke(sub_ctx))
  File "/usr/lib/python3/dist-packages/click/core.py", line 956, in invoke
    return ctx.invoke(self.callback, **ctx.params)
  File "/usr/lib/python3/dist-packages/click/core.py", line 555, in invoke
    return callback(*args, **kwargs)
  File "/usr/lib/python3/dist-packages/click/decorators.py", line 17, in new_func
    return f(get_current_context(), *args, **kwargs)
  File "/usr/lib/python3/dist-packages/patchbox/modules/module/cli.py", line 136, in activate
    ctx.obj.activate(module, autolaunch=False, autoinstall=autoinstall)
  File "/usr/lib/python3/dist-packages/patchbox/module.py", line 636, in activate
    self._install_module(module)
  File "/usr/lib/python3/dist-packages/patchbox/module.py", line 625, in _install_module
If someone wants to stick to Buster, try editing /etc/apt/sources.list.d/blokas.list to have the following contents:
deb http://apt.blokas.io/buster/ rpi main
Then run sudo apt update and try installing again.
