I am able to use USB Midi devices easily with MODEP on Pisound; however, when I plug in a USB microphone it is not recognized. I have identified the device using ‘arecord -l’ and have used the alsa_in command in an attempt to map the microphone to the jack audio server (see http://jackaudio.org/faq/multiple_devices.html). Using sudo, as the jack server for MODEP is started is under the root user:
sudo alsa_in -j “Fifine” -d hw:2 -q 1 2>&1 1> /dev/null &
The command seems to work, but I am not getting any sound or changes to the web gui. Anybody have any idea how to alter MODEP to recognize a USB microphone?
Thanks,
Nate
