In a normal configuration in/out, Digitakt master clock, digitone slave, when I Connect my Digital piano via Midi the BPM on my digitone double… from 120 to 240 BPM. however?
Giedrius
2
You have to place filters in Midihub in order not to duplicate unnecessary messages too many times. Try placing a type filter pipe straight after each input port, to keep only the types of messages that are necessary in that line.
It’s a good idea to use one Virtual bus just for sync information, so it’s kept out of the other lines.
Related topics
| Topic | Replies | Views | Activity | |
| Inaccurate Midi Clock When Passing Through Midihub? | 17 | 1173 | September 2, 2020 | |
| Midihub - Midiclock | 4 | 1961 | August 5, 2020 | |
| Advice about BPM/Clock usage | 7 | 1105 | October 17, 2020 | |
| Most Stable Clock: Digitakt or Midihub as master? | 1 | 535 | September 8, 2021 | |
| Distributing Clock from other sources | 3 | 1129 | July 5, 2021 | |
| Clock pipe and external bpm change | 2 | 239 | February 13, 2023 | |
| MIDI clock not send | 7 | 187 | April 5, 2024 | |
| Problem generating clock from CV to MIDI clock into MidiHub | 3 | 54 | January 8, 2025 | |
| Midihub + Elektron Devices (and others) | 10 | 1024 | January 21, 2021 | |
| Starting and Stopping Clock from Octatrack | 12 | 133 | December 10, 2024 |
