Midihub Clock modifiers
I’ve got an issue syncing my Torso T1 and Norand Mono MK1 (using the Midihub inbetween), the Norand always running halftime…
Is there a possibility to use the modifier “tempo div” as a tempo multiplier?
No, Tempo Div is just for dividing.
Some users encountering this type of problem have made Midihub the clock source.
See also @Giedrius’ workaround in a similar discussion to see if it works for you
Could you upload your preset here?
If the devices run OK when connected directly, there’s nothing really in Midihub that would change the tempo timings on its own, so it should work with Midihub in bettween.
