MidiHub as a Realtime Clock divider / multiplier / manipulator?
One of the reasons why I got Midihub is to use it as a real-time clock multiplier/divider/distributer.
The idea seems simple, to send the clock from my main sequencer, through the MidiHub distributing it’s clock divisions and multiplications to various drum computers and sequencers.
All live, on the fly, mashing up clock signals with an external midi controller.
This hasn’t really been working so far, clocks run out of phase and the sync delay only works when a stop/start signal is received.
Pretty much unusable in a live situation unless I am missing something?
Not sure if this is even possible without a stop/start messages but maybe there’s some workaround?
When working with modular you are able to send a clock reset every so many beats,steps or bars. This keeps everything locked together. Can something like this be implemented perhaps?
I would like to suggest some feature requests.
  1. would be helpful to have a divider / multiplier combo in one pipe.
  2. realtime sync delay
  3. realtime clock inversions or clock phase shifting. (1xxx becomes xx1x if that makes sense :slight_smile: )
    basically to change a snaredrum for instance, to shift from an upbeat to a downbeat and vise versa
This may or not be helpful to you but you can combine/multiply multiple clocks thru virtual pipelines and do the math to get different intended results. Coupled with the dividers, you have ways to quickly and specifically manipulate clock signals. Then you would map to the bypass of each clock/divider so you could do real-time instant clock shifting.
wow i totally missed this :confused: thanks for the suggestion!
In case you missed it @Giedrius made some interesting observations about Clock multiplying recently and added a patch for a Clock doubler (using LFO as he’d found Delay gave unreliable results).
I now remember it sent me off to do some testing on the Clock pipe’s new Tap Tempo to test how easy it would be to use it to set up a “mirror” clock to an external source. Mentioning this cos that might allow one to use the new Nudge Up|Down capabilities…
thanks for the heads up!
