Hello, I’m trying to control my XR18 mixer with a spare midi controller. It is seen in modep and usable from modep but I can’t connect to it in Mixing Station.
So I figured I’d not use the aggregated mode and only list my other controller in modep to keep the other one available for other apps… That didn’t work.
Is there some truth in my assumption that modep could be reservering that USB midi device ? Could it be prevented?
Alternatively is there a way to forward a midi message to a virtual output port or even directly map it to a Mackie network message?
Thanks for your help
What output do you get if you run aconnect -lio?
client 0: ‘System’ [type=kernel]
0 'Timer ’
1 'Announce ’
Connecting To: 128:0, 129:0
client 14: ‘Midi Through’ [type=kernel]
0 ‘Midi Through Port-0’
Connecting To: 129:0[real:0]
Connected From: 129:0
client 24: ‘X18/XR18’ [type=kernel,card=2]
0 'X18/XR18 MIDI 1 ’
client 28: ‘TSMIDI2.0’ [type=kernel,card=3]
0 ‘TSMIDI2.0 MIDI 1’
client 32: ‘MPK mini 3’ [type=kernel,card=4]
0 ‘MPK mini 3 MIDI 1’
Does it show the USB MIDI controller you intend to use?
If it’s getting listed, it should appear in mod-ui. MODEP does not do anything special with MIDI devices.
