Friends
I have a midi pedal “SINCO” (a four button USB pedal from aliexpress).
In the modep-ui I can set it as a MIDI PORT. But I cannot assign it to a pedal
When I click the “gear” icon to configure a pedal I click on the “slider” button and I get a configuration dialogue for that control and can assign it to MIDI or CV
When I click on MIDI I get a message in the dialogue: 'To map this parameter to your MIDI controller, press “save” and move the desired control on your “MIDI” device
When I do that, and toggle a button on the controller it has no discernible effect
Is there some other thing I should be doing?
I am using modep, with Pisound on a Pi4, a fresh install of Patchbox OS
cat /etc/issue
Raspbian GNU/Linux 11
My MIDI devices
$ aconnect -l
client 0: 'System' [type=kernel]
0 'Timer '
1 'Announce '
Connecting To: 129:0, 130:0
client 14: 'Midi Through' [type=kernel]
0 'Midi Through Port-0'
Connecting To: 130:0[real:0]
Connected From: 130:0
client 20: 'pisound' [type=kernel,card=1]
0 'pisound MIDI PS-0N78HB5'
client 24: 'SINCO' [type=kernel,card=2]
0 'SINCO MIDI 1 '
client 128: 'touchosc' [type=user,pid=519]
0 'touchosc '
client 131: 'pisound-ctl' [type=user,pid=914]
0 'pisound-ctl '
