Hi. This is basic but I can’t figure it out.
I have a midi instrument (Fishman Trippleplay Express) running into Abelton Live. It plays fine. Midihub is also runing/connected to my laptop, and it works fine for other interface to synth conenctions.
I want to send the midi signal from Ableton to Midihub to play my external synths, but I can’t get it to map.
In Live I have Midihub (Port 1,2,3,4) turned on for output. I’ve also tried each of these ports as the midi output for the track.
In Midihub I have tried the following:
From Virt (A,B,C,D) to Midi A (synth that works with other mapped controller)
From USB (A,B,C,D) to Midi A
Where am I going wrong?
To be clear, the midi controller (Tripple Play) can not be plugged directly into Midihub and needs to go through a DAW.
Jason
