Ableton + MIDIHUB
Okay, so I’m a new owner of MIDIHUB, and wanted to try out the effects in a DAW.
So I tried to use it setting up with two virtual pipes and send it inside Ableton, to an vst-plugin.
I see that it’s recieving MIDI from the notes that I’ve written, but it won’t send out anything to the plugin. Is there anything in the setup I’ve missed?
In the preferences in Ableton I’ve checked all the boxes, but still nothing.
I also tried to send MIDI via Ableton to one of my hardware synths with the same result. Not a sound, nothing. I don’t think my box is faulty and that is something that I’m just missing, but I read the documents but it doesn’t help me at all.
Should I use some other pipeline rather than the virtual?
I’ve also tried to use with Bespoke, and it didn’t work either. But it shows up. So I’m clueless.
All the best//Samuel
Hey Samuel,
Please upload the preset you’re using, preferably with info on what’s going into each input.
Thanks resonotter for such a quick answer, here’s the file.
Midihub 2024.08.05 15.22.50.mhp (349 Bytes)
Only using this with Ableton for the moment, but tried also with a Behringer TD-3.
Okay, so now I got drank some caffeine and started doing do the tutorial and realized I have been stupid the whole time. I’ve misunderstood USB and the VIRTUAL pipes all along…
I’m so sorry for taking your time…
Thanks for making an amazing product. Now it suddenly understand it. Everything works as it should now!
