if you delete then undo, the bypass assigns are not reinstated.
cheers
cheers
@Giedrius, I can’t reproduce this:
when I delete either a pipe or a pipeline then Undo, the reinstated pipes have the same Bypass status.
Tried with editor in both Connect and Disconnect states.
Thanks for checking.
I think it was me not being clear. I’ve assigned the bypass to an external midi signal so I can control it with an external CC. When I delete the chain and then undo, the reinstated chain has lost the CC assignment for the bypass.
Would you mind checking that? Of course I could have missed something.
cheers
I can reproduce it in the beta build, will be fixed. Thank you for checking and reporting. ![]()
