Can midihub sync to audio tempo clock
Don’t know what you mean exactly, Simon, so I’ll tell you what Midihub can do in clock terms:
- Receive MIDI clock messages via any of its 4 DIN ports & 4 USB ports
- Send MIDI clock from a
ClockPipe both internally to other pipes & externally - Filter out Clock messages (e.g. so external devices don’t conflict)
- Sync to Clock messages in various pipes like
Arp,Delay,LFO, etc. etc. - use a Tempo Divider pipe to output 1/2, 1/3 etc of incoming tempo
that mostly covers Midihub’s clock capabilities.
Drummachines and modular setup Can have analog tempo sync. Its like a metrome click. So I ment if it Can sync to a click. Hope you understand what Im trying to say. All the korg volca machinen has that clock, witch I use.
OK, with you now Simon.
No, in short.
As Midihub only deals with MIDI you’d need to find a way to respond to the audio pulses and turn them into some MIDI Event[1].
btw, As I recall, the Volca Sync-In isn’t so much a Clock as a “Next Step” Pulse to advance the sequencer (in this way it’s like the arps on pre-MIDI synths like the Juno-6), so if you use a drum machine to send out an irregular beat, the seq will follow that. MIDI Clock messages are generally more frequent than pulses.
[1] Midihub master>Volca>Audio pulse out?
