Hi all!
I have a QuNexus keyboard midi routed into Midihub and from there, into a midi capable Eurorack sequencer (Westlicht Performer). Then I have midi out going back into the Midihub and then into Ableton Live (it helps to punch in beats quickly). From my understanding, midi should be simply passing through this setup, however I’m not getting any velocity response from the QuNexus. I’ve been trying to find a way around this via Midihub pipes but I haven’t had any luck. The sequencer is monophonic, so that might be an issue.
Is this even possible to achieve?
Cheers!
