Midi Velocity Transform Help
Hi all, I’d love to hear any ideas on how to achieve this.
I’m trying to make a pipeline to control midi velocity from an incoming drum pad so that whatever velocity is received by midi hub it will output only one of two options. Like this
Input Vel = 0-19 transform to 0 or filter out
Input Vel = 20-59 transform to 60
Input Vel = 60-127 transform to 120
Hey @R808T
Three Replace Transforms will do it.
They will look like this:
R808T_Transform
Each Transform will act on any note in any Channel…
…but only when its Velocity falls Inside its Range
We Set Note Number to the same message type†…
but Set Velocity to a “fixed” value given by Argument 1
†As you say, “Vel = 0-19” could go to Note Off
(…but making them consistent allows you to alt-drag the first to create the others)
PS. “fixed” is in quotes cos it’s fixed only until you Map it to some control…
:exploding_head::exploding_head::exploding_head: that’s awesome!!! Thanks so much!
Welcome to the Midihub community!
