Could I send the note and velocity data to the Midihub, then send back note data and use the velocity data to control volume and filter cutoff on the Reface CS?
So I would be using the Reface as a midi controller for itself?
thanks! definitely seems like the midihub would be perfect for this. I’m not very experienced with midi, but I think I would be mapping velocity output data to both volume and filter.
Hey, @aevai, before you splash the cash on a Reface, is it worth pointing out that it would (probably) best respond to velocity from incoming CC messages while played monophonically or paraphonically?
(ie. playing, say, a quiet note while a loud note is still sounding wouldn’t give the expected results)
@erpel15 and @henrik have both raised topics about Reface & Midihub in the past year. If they’re still around perhaps they can confirm this.
