Hello!
I asked a question about ways to implement a “round-robin” style function with the current features available in the Midihub, but thought it might be worth submitting it for consideration here. I am using the Midihub to transform drum-triggers that are ending up at a Nord Drum 2. So the wish for this feature is from the perspective of a percussionist wanting to find ways of making interesting processes available in real-time, not transforming sequenced Midi.
A simple example would be every time a given note is received, trigger the following notes/Midi CC values in sequence, and cycle through the input values back to the first one. Potentially randomization or other patterns could yield interesting possibilities.
I am still attempting to achieve this following a response to the post I made in the general Midihub section. It is rather convoluted, so I thought I would submit this here in case it seems like a potentially useful or interesting feature to implement for others too. A lot of drum samplers work with round-robin and random cycling, so it’s a common feature within software setups with drums, usually to avoid the “machine gun” effect of a sound cutting itself of and clearly repeating. I’m more interested in a sort of creative interactive setup for hybrid (acoustic/electric) drumming, but just to say there are clearly other potential uses if such a feature were possible to realize. You’ll have to pardon my ignorance if it isn’t possible, or is too complicated to execute to make it worthwhile.
