Rescale and Limiter not working with Channel Pressure
I’m trying to rescale the channel pressure of my main keyboard (prophet rev2) to another synth. Rescale/limiter work just fine for note velocity and cc, but not for channel pressure. I’ve set up a video that demonstrates this here.
Pretty simple setup, the midi from the keyboard is going to a virtual in, which is going to two different tracks in my DAW, the top one is demonstrating the output from rescale/limiter, the bottom one is showing what I’m actually doing. You can see that it does what you’d expect for note velocity and the modwheel, but it doesn’t rescale channel pressure. I know my keyboard is putting out channel pressure and not poly aftertouch since it can’t do that, and you can see that the DAW recognizes it as channel pressure.
Any idea what the issue could be?
Hi, thank you for reporting this, indeed there’s a bug, we’ll get it fixed. :slight_smile:
Awesome, thanks so much! Absolutely love what you all are doing!
