Pitch Bend Rescaling
Is there a way to rescale pitch bend commands? Chase Bliss Mood mkii is hard-set to 4 semitones, I would like to make it only move by 2 semitones.
I’ve had a go at using 2 Transform pipes and a Rescale pipe to convert pb to cc then back to pb but can’t really get my head around it (any help with this would be great).
Ideally though if its possible to add pitch bend values to the Recale pipe in a firmware update that would be awesome!
Many thanks
There’s an easier solution :slight_smile: Place an Equalizer pipe and configure it like this to get 50% reduction in Pitch Bend depth:
Ah amazing, didn’t think to check that pipe! Works perfectly, thanks very much!
