Velocity Remap (like Note Remap)
A “Velocity Remap” that works like the “Note Remap” would be very useful.
Properties would be:
“In Low” (1…127)
“In High” (1…127)
“Out Low” (1…127)
“Out High” (1…127)
A few use cases: compressing/expanding/clipping/inverting velocities, velocity curves based on breakpoints (using parallel branches), replacing all velocities by a constant velocity, velocity dependant separation or layering, …
Thank you for your attention.
Hey, @Stephan_Schmitt, this functionality is already available with the Rescale Pipe.
There is a distinction between Remaps and Rescale
shown here:
So if Rescale has In Low = 17, then all velocities < 17 will become 17, etc.
If instead you want to discard all notes with velocities outside the In Low|High, you would precede the Rescale pipe by a Transform pipe set to Drop Mode:
This discards all notes with velocities outside the velocity range [17;98]…
…(using Outside Range allows us to map the Transform range using the same mappings as to Rescale In Low|High range!)
Thank you for the quick reply, resonotter!
The combination of Transform (Drop) and Rescale seems to fullfil my requirements.
Good!
Btw, if you want to experiment with...
…and your incoming notes are on one channel (say Channel 1)
try this:
  • use a series of Replace Transforms instead to cover your velocity range
    (say [0;56], [57;72], [73;96], [97;127])
  • set these Transforms to change only the channel of the notes
    (say [0;56] → 6, [57;72] → 7, [73;96] → 8, [97;127] → 9)
  • then have your parallel pipelines each start with a Channel Remap
    [6;6] → [1;1], [7;7] → 1, etc
    (recall that Channel Remap also acts like a channel filter! :smile:)
  • each of these pipelines will then have its own Rescale, Equalizer, etc..
  • …before merging your modified Note On messages (to rejoin the Note Off from another pipeline)
This approach works nicely. Just remember to Filter out Clock!
Ah - interesting!
I will try that. Thank you!
I realised after posting, Stephan, that there’s a neater way:
It leverages this rather unusual Transform setting…
…where the channel is set to the Velocity
  • this gives 16 “velocity bands”
  • which can then be grouped together by different Channel Remaps
Give it a try; it’s rather pleasing.
