Hi all,
I’ve set up four presets which I can access by the “Prorgam +” and “Program -” knob on my keyboard. For this, I had to go to “Device - Settings” and set Input Port to ‘MIDI A’ and the MIDI Channel. Now some questions:
Is the Program Change that my keyboard sends in order to increase the preset ‘eaten up’ by this operation or is it still available and processed by the preset just loaded? That would be great for sending some initializing data.
When I change the preset by the program knob on my keyboard, I can see which program is active on my Midihub. However, when I want to change the preset with the knob on the Midihub, the LED just blinks 2 times and always goes to preset 1. Upon pressing it again, it blinks twice and rests at preset 1. So I have no idea which preset is in effect when using the knob. Is this intended?
When the MidiHub ist powered off and on again, is it initialized as preset 1 or the last active preset?
On the settings, you are able to set the Input Port to ‘USB A’. How is this different from Input Port ‘MIDI A’?
Thank you,
Alex
