Hi, I’m using Pisound with SamplerBox, and I’ve added some extra buttons. I tried to avoid the GPIO pins that Pisound uses. I bought a GPIO splitter so I can connect both the Pisound and my breadboard. However, when I run SamplerBox and try to use the buttons, they don’t work—they only work when the Pisound isn’t connected. So my question is: does Pisound actually leave some GPIO pins unused? For example, I use GPIO 13 to change presets, and when I start SamplerBox it goes into an infinite loop as if the button is always pressed. GPIO 19, which I use as the select button, also seems to loop. There are other gpios having the same problem. how can i fix this?
Giedrius
2
Hi, those pins are used by Pisound. Pick from the available GPIO pins as listed in the table at https://blokas.io/pisound/docs/general-specifications/#pinout-of-pisound-header.
Related topics
| Topic | Replies | Views | Activity | |
| Does Pisound using all GPIOs? | 14 | 3337 | May 28, 2024 | |
| Using button without pisound | 22 | 2364 | February 13, 2026 | |
| GPIO Leds' Pins | 2 | 737 | February 18, 2019 | |
| Pinout pisound header as the button | 7 | 1354 | June 19, 2020 | |
| Gpio Expand board recomendation | 3 | 1032 | April 13, 2023 | |
| Free up Gpio 17? | 2 | 456 | June 4, 2021 | |
| Blown Pisound/GPIO? | 2 | 829 | September 21, 2018 | |
| Encoder pins issue | 12 | 173 | October 27, 2025 | |
| Using pisound's other GPIOs for other purpose? | 8 | 241 | February 20, 2024 | |
| [SOLVED] Button not working | 6 | 85 | September 13, 2024 |
