Is there a way to do the preset change of the MIDIHUB via Note Numbers? At the moment I can do this only with Program Changes on a specific port in the settings menu.
Maybe the Transform Pipe could help?
It would be possible if you did a MIDI loopback, to convert it to Program Change and send to a DIN-5 MIDI input.
Hi Racecube,
I’ve been doing this using the following chain ;
FROM ? - CHANNEL FILTER - RANGE FILTER - TRANSFORM - TO ?
For the range I put notes I want to use as a trigger, then for the Transform I put the following ;
Mode - Replace
What - Note On
Into - Programme change
Set Programme - Arg1
then Argument 1 & 3 will determine the programme number (I think!).
I seem to remember 0 being programme 1, 1 being programme 2 etc.
Hope that helps!
