Love the midihub so far.
My expert Sleepers General CV module receives on all 16 midi channels. There are 128 sounds onboard selectable via program change on each channel (0 - 127). So you could have 16 sequences running, one on each channel, with a different program selected.
What I’d really like to do is map so that 1 single cc knob on the keystep 37 would then sweep through programs 0-127. So treat a program change value like you would a cc value.
I have played around with the transform pipe but can’t quite find a way to do what I’m looking for - and I’m getting confused by the arguments and values.
At the moment I have successfully set it in the transform pipe so a note on value can select the program (and have a cc to bypass the pipe) However I don’t think I have 127 keys and it requires you to stop playing to map, so thinking one knob to do this job would be much better. Is it possible?
Update: Figured it out!
Mode: Replace
What: CC
Into: PC
Set Program Number to: Arg 1
Arg 1: VALUE - then Map Arg 1 to cc
(in my case, map same cc to every 16 channels)
Now I have unlocked a 16 part multitimbral general midi polyphone. Ace!
