Pisound / Pi 5 - what's the latest on enclosures and cooling
The Pi will manage the fan speed automatically based on temperature. But if you want to override that there are some config txt changes that you can apply: https://forums.raspberrypi.com/viewtopic.php?t=367374
I’m finally getting around to assembling the Pi 5, PiSound and case. I am stuck though, putting the top on. The holes in the top piece don’t align with the projections on the top of the jack side and the top won’t go down over them. The jack washers are on the outside. Did I miss a step or something?
Please see the exploded graphical image of the Pisound and the Case, as well as the steps decribed in the recommended order of assembly:
Keep in mind that you have to place the sides the right way up too, so the Blokas logo is not upside down.
Did you get the Pisound and the Acrylic Case from our online store? We currently ship v1.2 Pisound and the Acrylic Case for it. The versions of Pisound and the Case must match up.
Yes … it’s from the store, purchased together a few weeks ago. I did get it assembled; I had to apply more pressure on the sides in different directions but it’s all together now.
