You can freely use Pisound v1.0 with Pi 4 or Pi 5. If you hit the stuck on reboot issue as mentioned in the thread you linked, I’d recommend enabling the software workaround as described.
In our experience, Pi 5 works best with an active fan, Pi 4 can do ok without it. They fit best under v1.2 Pisound.
Latency is just a bit too high for me right now, and I also have problems with restarting the device. And two out of five times midi is not working on startup
I just don’t come to a point where the PiSound is working 100% reliably for me, and I would need that in a live situation. I wanna use it as a Pure Data live effect box
I would hope that an update to a Rasp 4 B would solve those problems
@FullHorst when I used a RPi4 with PiSound I added the Pimorini Fan Shim to help keep the setup cool.
If you decide to go this route don’t install the software, just let the fan run. Using this setup I never had any reliability issues and I used that live every week.
I’ve since upgraded to a RPi5 with active cooler with the newer PiSound. Love it! If you can swing the 5 with the active cooler and the new PiSound it certainly helps, especially when running NAM in MODEP.
@FullHorst yes, it does indeed fit inside the case. The only modification might be to remove the standoffs in that corner or find some standoffs of varying height.
I’m using Pisound for analogue sound capture from my vinyl player. After AD conversion it is streamed to Apple HomePods in my household.
The pisound + RPI 4B unit is contained in the Blokas Pisound Case. No cooling.
