Current Status of RPi4, Pisound, & Pimoroni Fan Shim
As of today with the latest Blokas software, RPi4 B and Pimoroni Fan Shim, are there any know compatibility issues? I recall reading about a problem in the past but cannot find if it has been resolved.
Thanks,
Harry
With a new RPI 4 and newest pisound and fan shim it does not work. Pisound is detected but it failed to start jack. If I remove the fan shim pisound is working again. Thus I cannot even test if the fan shim service is leading to audio problems. Maybe it’s a power problem? Some (power) pins are used by both devices? I’m using the standard power supply. But I have no clue…
I’m running the latest version of the patchbox OS with a RPi4 B and have the pimoroni fan shim. The fan can be physically installed but it has several conflicts which to my knowledge have not been fixed. Both the fan shim and Pisound button interact with each other and cause issues. Also the auto-run script for the fan breaks Jack and I have yet to find the source of the issue.
-Hope this helps
Thanks fro the feedback. I had seen this at the Pimoroni site “Because Fan SHIM uses pin BCM18 to control the fan, and this pin is also used by I2S audio devices, you won’t be able to use I2S DACs like pHAT DAC, pHAT BEAT, and the IQAudio boards at the same time as Fan SHIM” and thought there might be an issue. I’ll try heat sinks first and if there is a heat problem I’ll bypass BCM18 and hardwire the fan ON and not use the fan software.
Sounds like a plan, I’m new to the raspbery pi so if you have success making the fan work with the pisound please post about it or reply to my comment :slight_smile: it would be very apreciated.
I use rpi4 2gb ram version with pimoroni fan shim. It works pretty good, cooling down rpi, Im just not using auto-scripts to control fan ratio. Without it, in the pisound case, rpi got warm pretty fast, so ive chosen that way.
So in that case, the I²S pin used by the fan hat can be used for Pisound?
I didnt check audio, but midi works, pisound is available, jack starts. I can use puredata and patchbox and they looks like working fine.
patch@patchbox:~ $ dmesg
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.19.71-rt24-v7l+ (giedrius@giedrius-vb) (gcc version 4.8.3 20140303 (prerelease) (crosstool-NG linaro-1.13.1+bzr2650 - Linaro GCC 2014.03)) #1 SMP PREEMPT RT Wed Mar 11 17:15:58 EET 2020
[    0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[    0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.1
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] cma: Reserved 256 MiB at 0x000000001ec00000
[    0.000000] On node 0 totalpages: 458752
[    0.000000]   DMA zone: 1728 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 196608 pages, LIFO batch:63
[    0.000000]   HighMem zone: 262144 pages, LIFO batch:63
[    0.000000] random: get_random_bytes called from start_kernel+0x80/0x4cc with crng_init=0
[    0.000000] percpu: Embedded 18 pages/cpu s41536 r8192 d24000 u73728
[    0.000000] pcpu-alloc: s41536 r8192 d24000 u73728 alloc=18*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 457024
[    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 cma=64M cma=256M video=HDMI-A-1:1280x720M@60 smsc95xx.macaddr=DC:A6:32:39:7C:5C vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=3ac474d7-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
[    0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 1538468K/1835008K available (8192K kernel code, 661K rwdata, 2364K rodata, 2048K init, 986K bss, 34396K reserved, 262144K cma-reserved, 1048576K highmem)
[    0.000000] Virtual kernel memory layout:
                   vector  : 0xffff0000 - 0xffff1000   (   4 kB)
                   fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
                   vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
                   lowmem  : 0xc0000000 - 0xf0000000   ( 768 MB)
                   pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
                   modules : 0xbf000000 - 0xbfe00000   (  14 MB)
                     .text : 0x(ptrval) - 0x(ptrval)   (10208 kB)
                     .init : 0x(ptrval) - 0x(ptrval)   (2048 kB)
                     .data : 0x(ptrval) - 0x(ptrval)   ( 662 kB)
                      .bss : 0x(ptrval) - 0x(ptrval)   ( 987 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] ftrace: allocating 28127 entries in 83 pages
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu: 	RCU priority boosting: priority 1 delay 500 ms.
[    0.000000] 	No expedited grace period (rcu_normal_after_boot).
[    0.000000] 	Tasks RCU enabled.
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[    0.000005] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[    0.000014] Switching to timer-based delay loop, resolution 18ns
[    0.000247] Console: colour dummy device 80x30
[    0.001081] console [tty1] enabled
[    0.001110] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
[    0.001121] pid_max: default: 32768 minimum: 301
[    0.001420] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.001434] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.002357] CPU: Testing write buffer coherency: ok
[    0.002848] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.060120] Setting up static identity map for 0x200000 - 0x20003c
[    0.100092] rcu: Hierarchical SRCU implementation.
[    0.180256] smp: Bringing up secondary CPUs ...
[    0.320880] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.461089] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.601333] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.601532] smp: Brought up 1 node, 4 CPUs
[    0.601623] SMP: Total of 4 processors activated (432.00 BogoMIPS).
[    0.601656] CPU: All CPU(s) started in HYP mode.
[    0.601686] CPU: Virtualization extensions available.
[    0.602927] devtmpfs: initialized
[    0.623977] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
[    0.624638] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.624699] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.633409] pinctrl core: initialized pinctrl subsystem
[    0.635440] NET: Registered protocol family 16
[    0.640524] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[    0.643336] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.643380] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.643625] Serial: AMBA PL011 UART driver
[    0.648933] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[    0.729755] bcm2835-dma fe007000.dma: DMA legacy API manager at (ptrval), dmachans=0x1
[    0.734406] vgaarb: loaded
[    0.734984] SCSI subsystem initialized
[    0.735447] usbcore: registered new interface driver usbfs
[    0.735585] usbcore: registered new interface driver hub
[    0.735811] usbcore: registered new device driver usb
[    0.751427] raspberrypi-firmware soc:firmware: Attached to firmware from 2020-11-30 22:12, variant start
[    0.771440] raspberrypi-firmware soc:firmware: Firmware hash is ab1181cc0cb6df52bfae3b1d3fef0ce7c325166c
[    0.784074] clocksource: Switched to clocksource arch_sys_counter
[    0.992230] VFS: Disk quotas dquot_6.6.0
[    0.992383] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.993038] FS-Cache: Loaded
[    0.993366] CacheFiles: Loaded
[    0.994408] simple-framebuffer 3e843000.framebuffer: framebuffer at 0x3e843000, 0x384000 bytes, mapped to 0x(ptrval)
[    0.994460] simple-framebuffer 3e843000.framebuffer: format=a8r8g8b8, mode=1280x720x32, linelength=5120
[    0.999850] Console: switching to colour frame buffer device 160x45
[    1.004404] simple-framebuffer 3e843000.framebuffer: fb0: simplefb registered!
[    1.023474] NET: Registered protocol family 2
[    1.025005] tcp_listen_portaddr_hash hash table entries: 512 (order: 2, 16384 bytes)
[    1.025138] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    1.025333] TCP bind hash table entries: 8192 (order: 5, 229376 bytes)
[    1.025724] TCP: Hash tables configured (established 8192 bind 8192)
[    1.026103] UDP hash table entries: 512 (order: 3, 32768 bytes)
[    1.026238] UDP-Lite hash table entries: 512 (order: 3, 32768 bytes)
[    1.026894] NET: Registered protocol family 1
[    1.027998] RPC: Registered named UNIX socket transport module.
[    1.029856] RPC: Registered udp transport module.
[    1.031676] RPC: Registered tcp transport module.
[    1.033494] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.035480] PCI: CLS 0 bytes, default 64
[    1.042378] Initialise system trusted keyrings
[    1.044675] workingset: timestamp_bits=14 max_order=19 bucket_order=5
[    1.071112] FS-Cache: Netfs 'nfs' registered for caching
[    1.074312] NFS: Registering the id_resolver key type
[    1.076124] Key type id_resolver registered
[    1.077875] Key type id_legacy registered
[    1.079606] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.086044] Key type asymmetric registered
[    1.087806] Asymmetric key parser 'x509' registered
[    1.089896] bounce: pool size: 64 pages
[    1.091691] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[    1.103943] io scheduler noop registered
[    1.105875] io scheduler deadline registered (default)
[    1.108292] io scheduler cfq registered
[    1.110072] io scheduler mq-deadline registered (default)
[    1.111804] io scheduler kyber registered
[    1.119017] brcm-pcie fd500000.pcie: could not get clock
[    1.120800] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[    1.122541] brcm-pcie fd500000.pcie:   MEM 0x600000000..0x603ffffff -> 0xf8000000
[    1.194162] brcm-pcie fd500000.pcie: link up, 5.0 Gbps x1 (!SSC)
[    1.196380] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[    1.198094] pci_bus 0000:00: root bus resource [bus 00-01]
[    1.199794] pci_bus 0000:00: root bus resource [mem 0x600000000-0x603ffffff] (bus address [0xf8000000-0xfbffffff])
[    1.201554] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[    1.201724] pci 0000:00:00.0: PME# supported from D0 D3hot
[    1.204937] PCI: bus0: Fast back to back transfers disabled
[    1.206947] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[    1.207080] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[    1.207485] pci 0000:01:00.0: PME# supported from D0 D3cold
[    1.210568] PCI: bus1: Fast back to back transfers disabled
[    1.212262] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[    1.213950] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[    1.215741] pci 0000:00:00.0: PCI bridge to [bus 01]
[    1.217348] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
[    1.219305] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
[    1.221536] pcieport 0000:00:00.0: Signaling PME with IRQ 56
[    1.223632] pcieport 0000:00:00.0: AER enabled with IRQ 56
[    1.225520] pci 0000:01:00.0: enabling device (0140 -> 0142)
[    1.233402] iproc-rng200 fe104000.rng: hwrng registered
[    1.235414] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[    1.238035] vc-sm: Videocore shared memory driver
[    1.240349] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[    1.266607] brd: module loaded
[    1.296100] loop: module loaded
[    1.299233] Loading iSCSI transport class v2.0-870.
[    1.304478] libphy: Fixed MDIO Bus: probed
[    1.306773] bcmgenet fd580000.genet: failed to get enet clock
[    1.308380] bcmgenet fd580000.genet: GENET 5.0 EPHY: 0x0000
[    1.309973] bcmgenet fd580000.genet: failed to get enet-wol clock
[    1.311555] bcmgenet fd580000.genet: failed to get enet-eee clock
[    1.313126] bcmgenet: Skipping UMAC reset
[    1.315161] unimac-mdio unimac-mdio.-19: DMA mask not set
[    1.334177] libphy: bcmgenet MII bus: probed
[    1.375125] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus at 0x(ptrval)
[    1.378624] usbcore: registered new interface driver r8152
[    1.380335] usbcore: registered new interface driver lan78xx
[    1.382000] usbcore: registered new interface driver smsc95xx
[    1.384026] xhci_hcd 0000:01:00.0: xHCI Host Controller
[    1.385742] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[    1.390355] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000001000000890
[    1.392531] genirq: irq_chip Brcm_MSI did not update eff. affinity mask of irq 57
[    1.394513] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[    1.397716] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.399345] usb usb1: Product: xHCI Host Controller
[    1.400954] usb usb1: Manufacturer: Linux 4.19.71-rt24-v7l+ xhci-hcd
[    1.402589] usb usb1: SerialNumber: 0000:01:00.0
[    1.405543] hub 1-0:1.0: USB hub found
[    1.407235] hub 1-0:1.0: 1 port detected
[    1.409642] xhci_hcd 0000:01:00.0: xHCI Host Controller
[    1.411233] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[    1.412813] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[    1.415025] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[    1.416661] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.418285] usb usb2: Product: xHCI Host Controller
[    1.419886] usb usb2: Manufacturer: Linux 4.19.71-rt24-v7l+ xhci-hcd
[    1.421512] usb usb2: SerialNumber: 0000:01:00.0
[    1.424376] hub 2-0:1.0: USB hub found
[    1.426053] hub 2-0:1.0: 4 ports detected
[    1.429838] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    1.457186] dwc_otg fe980000.usb: base=(ptrval)
[    1.659546] Core Release: 2.80a
[    1.661077] Setting default values for core params
[    1.662600] Finished setting default values for core params
[    1.774122] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[    1.866760] Using Buffer DMA mode
[    1.868310] Periodic Transfer Interrupt Enhancement - disabled
[    1.869880] Multiprocessor Interrupt Enhancement - disabled
[    1.871456] OTG VER PARAM: 0, OTG VER FLAG: 0
[    1.873055] Dedicated Tx FIFOs mode
[    1.875272] WARN::dwc_otg_hcd_init:1043: FIQ DMA bounce buffers: virt = ded34000 dma = 0x00000000ded34000 len=9024
[    1.876990] FIQ FSM acceleration enabled for :
               Non-periodic Split Transactions
               Periodic Split Transactions
               High-Speed Isochronous Endpoints
               Interrupt/Control Split Transaction hack enabled
[    1.885171] dwc_otg: Microframe scheduler enabled
[    1.885250] WARN::hcd_init_fiq:457: FIQ on core 1
[    1.885259] WARN::hcd_init_fiq:458: FIQ ASM at c0793f2c length 36
[    1.885268] WARN::hcd_init_fiq:497: MPHI regs_base at f0810200
[    1.885307] dwc_otg fe980000.usb: DWC OTG Controller
[    1.891884] dwc_otg fe980000.usb: new USB bus registered, assigned bus number 3
[    1.893740] dwc_otg fe980000.usb: irq 38, io mem 0x00000000
[    1.895451] Init: Port Power? op_state=1
[    1.897015] Init: Power Port (0)
[    1.898917] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[    1.900515] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.902113] usb usb3: Product: DWC OTG Controller
[    1.903705] usb usb3: Manufacturer: Linux 4.19.71-rt24-v7l+ dwc_otg_hcd
[    1.905392] usb usb3: SerialNumber: fe980000.usb
[    1.908196] hub 3-0:1.0: USB hub found
[    1.909858] hub 3-0:1.0: 1 port detected
[    1.912642] dwc_otg: FIQ enabled
[    1.912656] dwc_otg: NAK holdoff enabled
[    1.912669] dwc_otg: FIQ split-transaction FSM enabled
[    1.912691] Module dwc_common_port init
[    1.913076] usbcore: registered new interface driver uas
[    1.914947] usbcore: registered new interface driver usb-storage
[    1.916896] mousedev: PS/2 mouse device common for all mice
[    1.921181] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[    1.923196] bcm2835-cpufreq: min=600000 max=1500000
[    1.926315] sdhci: Secure Digital Host Controller Interface driver
[    1.927893] sdhci: Copyright(c) Pierre Ossman
[    1.930348] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
[    1.932841] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.938903] hidraw: raw HID events driver (C) Jiri Kosina
[    1.940885] usbcore: registered new interface driver usbhid
[    1.942514] usbhid: USB HID core driver
[    1.945319] vchiq: vchiq_init_state: slot_zero = (ptrval), is_master = 0
[    1.949343] [vc_sm_connected_init]: start
[    1.956932] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[    1.958703] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    1.960548] usb 1-1: Product: USB2.0 Hub
[    1.960667] [vc_sm_connected_init]: end - returning 0
[    1.962989] Initializing XFRM netlink socket
[    1.963057] NET: Registered protocol family 17
[    1.963342] Key type dns_resolver registered
[    1.963656] Registering SWP/SWPB emulation handler
[    1.965249] registered taskstats version 1
[    1.965269] Loading compiled-in X.509 certificates
[    1.975870] hub 1-1:1.0: USB hub found
[    1.977773] hub 1-1:1.0: 4 ports detected
[    1.991164] uart-pl011 fe201000.serial: cts_event_workaround enabled
[    1.992899] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 34, base_baud = 0) is a PL011 rev2
[    1.999410] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[    2.001974] brcmstb_thermal fd5d2200.thermal: registered AVS TMON of-sensor driver
[    2.004810] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[    2.006485] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[    2.035123] sdhci-iproc fe340000.emmc2: Linked as a consumer to regulator.1
[    2.055226] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[    2.058655] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    2.062018] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    2.066732] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[    2.069639] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
[    2.071757] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    2.083965] of_cfs_init
[    2.087020] of_cfs_init: OK
[    2.089733] random: fast init done
[    2.092300] Waiting for root device PARTUUID=3ac474d7-02...
[    2.154331] mmc1: new high speed SDIO card at address 0001
[    2.175559] mmc0: new ultra high speed DDR50 SDHC card at address 0001
[    2.179022] mmcblk0: mmc0:0001 JB1RT 29.8 GiB
[    2.182763]  mmcblk0: p1 p2
[    2.237120] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    2.238862] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[    2.241530] devtmpfs: mounted
[    2.253608] Freeing unused kernel memory: 2048K
[    2.255541] Run /sbin/init as init process
[    2.314173] usb 1-1.3: new full-speed USB device number 3 using xhci_hcd
[    2.774235] systemd[1]: System time before build time, advancing clock.
[    2.897836] NET: Registered protocol family 10
[    2.901801] Segment Routing with IPv6
[    2.941657] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[    2.946747] systemd[1]: Detected architecture arm.
[    2.967129] systemd[1]: Set hostname to <patchbox>.
[    3.856487] systemd[1]: File /lib/systemd/system/systemd-journald.service:12 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[    3.860310] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[    4.164483] usb 1-1.3: device descriptor read/64, error -32
[    4.391762] random: systemd: uninitialized urandom read (16 bytes read)
[    4.405532] random: systemd: uninitialized urandom read (16 bytes read)
[    4.419584] systemd[1]: Created slice system-getty.slice.
[    4.420474] usb 1-1.3: New USB device found, idVendor=16d0, idProduct=0c9c, bcdDevice= 1.01
[    4.420490] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    4.420505] usb 1-1.3: Product: Midihub MH-3JGB8JW
[    4.420518] usb 1-1.3: Manufacturer: Blokas
[    4.420529] usb 1-1.3: SerialNumber: MH-3JGB8JW
[    4.435951] random: systemd: uninitialized urandom read (16 bytes read)
[    4.439330] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    4.473599] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[    4.482829] systemd[1]: Listening on fsck to fsckd communication Socket.
[    4.488655] systemd[1]: Listening on initctl Compatibility Named Pipe.
[    5.614644] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[    5.752558] systemd-journald[145]: Received request to flush runtime journal from PID 1
[    7.537719] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x0000ffff
[    7.565212] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00000fff
[    7.590271] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x0000ffff
[    7.612436] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x0000ffff
[    7.672371] media: Linux media interface: v0.10
[    7.759069] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[    7.791584] videodev: Linux video capture interface: v2.00
[    7.810430] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[    7.810462] [vc_sm_connected_init]: start
[    7.867768] [vc_sm_connected_init]: installed successfully
[    8.032113] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[    8.082543] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[    8.131403] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[    8.224732] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[    8.224794] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[    8.254646] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[    8.254693] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[    8.261308] : bcm2835_codec_get_supported_fmts: port has more encoding than we provided space for. Some are dropped.
[    8.302691] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[    8.302738] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[    8.523878] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[    8.660842] bcm2835_audio soc:audio: card created with 8 channels
[    8.932244] pisound: Searching for spi device...
[    8.932268] pisound: 	Found!
[    9.069398] pisound: Detected Pisound card:
[    9.069417] pisound: 	Serial:           PS-35G5P84
[    9.069431] pisound: 	Firmware Version: 1.03
[    9.069445] pisound: 	Hardware Version: 1.1
[    9.069458] pisound: 	Id:               1e93153555313630360c1716
[    9.112824] snd-rpi-pisound soc:sound: snd-soc-dummy-dai <-> fe203000.i2s mapping ok
[    9.219938] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    9.279309] vc4-drm soc:gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
[    9.279335] checking generic (3e843000 384000) vs hw (0 ffffffffffffffff)
[    9.279351] fb: switching to vc4drmfb from simple
[    9.279649] Console: switching to colour dummy device 80x30
[    9.361440] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    9.387088] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 1
[    9.429222] [drm] Initialized vc4 0.0.0 20140616 for soc:gpu on minor 0
[    9.429245] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    9.429260] [drm] No driver support for vblank timestamp query.
[    9.429274] [drm] Setting vblank_disable_immediate to false because get_vblank_timestamp == NULL
[    9.431259] vc4-drm soc:gpu: HDMI-A-1: EDID is invalid:
[    9.431281] 	[00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    9.431296] 	[00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    9.431310] 	[00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    9.431324] 	[00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    9.431338] 	[00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    9.431352] 	[00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    9.431366] 	[00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    9.431380] 	[00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    9.534680] brcmfmac: F1 signature read @0x18000000=0x15264345
[    9.551274] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[    9.586231] usbcore: registered new interface driver brcmfmac
[    9.620464] Console: switching to colour frame buffer device 160x45
[    9.645636] vc4-drm soc:gpu: fb0: DRM emulated frame buffer device
[    9.857358] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[    9.871012] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Mar 23 2020 02:19:54 version 7.45.206 (r725000 CY) FWID 01-88ee44ea
[   10.580463] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
[   10.617614] usbcore: registered new interface driver cdc_acm
[   10.617634] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[   10.850203] usbcore: registered new interface driver snd-usb-audio
[   11.497504] random: crng init done
[   11.497523] random: 7 urandom warning(s) missed due to ratelimiting
[   14.514987] uart-pl011 fe201000.serial: no DMA platform data
[   14.562035] 8021q: 802.1Q VLAN Support v1.8
[   15.444626] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   15.444639] brcmfmac: power management disabled
[   15.684825] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
[   16.598096] bcmgenet: Skipping UMAC reset
[   16.694841] bcmgenet fd580000.genet: configuring instance for external RGMII (no delay)
[   16.695134] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   17.754358] bcmgenet fd580000.genet eth0: Link is Down
[   20.838733] fuse init (API version 7.27)
[   21.327197] Bluetooth: Core ver 2.22
[   21.327284] NET: Registered protocol family 31
[   21.327290] Bluetooth: HCI device and connection manager initialized
[   21.327313] Bluetooth: HCI socket layer initialized
[   21.327331] Bluetooth: L2CAP socket layer initialized
[   21.327395] Bluetooth: SCO socket layer initialized
[   21.360614] Bluetooth: HCI UART driver ver 2.3
[   21.360626] Bluetooth: HCI UART protocol H4 registered
[   21.360706] Bluetooth: HCI UART protocol Three-wire (H5) registered
[   21.360949] Bluetooth: HCI UART protocol Broadcom registered
[   21.630065] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[   22.086477] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   22.086486] Bluetooth: BNEP filters: protocol multicast
[   22.086509] Bluetooth: BNEP socket layer initialized
[   22.196653] Bluetooth: RFCOMM TTY layer initialized
[   22.196768] Bluetooth: RFCOMM socket layer initialized
[   22.196798] Bluetooth: RFCOMM ver 1.11
Audio works. When the pimoroni fan-shim service is enabled something blocks audio or jack. Going into X the digital audio still works, just the jack based one is dead. When the pimoroni service is disabled, analog audio returns. Running the first use wizard gives the output that jackd cannot be restarted while the pimoroni service is enabled. I am still new to this, can’t really analyze, but I am pretty disappointed at this finding as the fan is quite loud, and I would like to see it switched off if the pi isn’t too warm… I bought the pimoroni pimoroni fan because someone recommended it in this forum - that was a misguided reco…
Actually the service can be enabled, it must just not be started. Here someone investigated - not with respect to pisound, but generally, about the systemintrusiveness of the “smart” fan:
Same thing with vanilla RpiOS (just the pisound hardware, no patchbox stuff). When the pimoroni service is running pisound and jack are dead.
Yes, the fan uses the same pins for controlling its speed that must be used for audio data transfer, so both functions can’t work at the same time.
FWIW, I just installed the pimoroni fan shim in my raspberry pi and am also using the Pisound interface. I also have the acrylic case from Blokas as well. From a physical perspective one of the standouts cannot be installed. I tried and it would be too high compared to the other 3 to put the case back together. It also threatened to bend the corner of the fan shim board. So I just used the other 3 and it seems to be fine. I did not install the software to control the fan. In my case it’s just always on and have had no problems with interference with Pisound. Some photos attached for reference.
Heya, since my pi4 got really hot within the acrylic case and i had some fanshims around I tried this out, too. Without installing any fanshim software it seems to work without issues, always running at top speed. Top speed is pretty loud though – is there a way to change the speed without running the fanshim software, or is it possible to install the fanshim software, have it throttle to a lower speed and disable before jack starts?
Have any of you experienced the fan to be “too” loud and find some workaround?
best,
dormir
Mine is not loud at all, very quiet.
thanks for sharing your insights, getting one of this fans today since Im hitting 80ÂşC almost with high audio processing
Turns out for some reason I had arm_boost=1 on my boot config …
disabling overclocking leads to 65ÂşC max
(In 2023) I just installed the Pumoroni fan shim on my Pi 4 4GB. I also have PiSound and the PiSound case. That is not going well. The back of the Pisound audio I/O rest on the fan and prevent it from spinning. With patient tweaking of screws and bolts and moving of connectors I can suspend the Pisound just barely above the fan, but then I can’t put the case together (defeating the purpose of getting the fan. I have not installed the fan shim service.
I would love other options for cooling that work with the RPi4, PiSound, and PiSound Case.
My most recent use of this combo is for Zynthian “stable-2211”. Without the fan and case, Zynthian launches fine and i can select and use Pisound as the audio interface. However, with the pisound case - it gets too hot and the thermometer displays regularly.
I loved the idea of PiSound, but I don’t use exposed electronics in my setups and need a case…if you have another no-solder option (e.g. a specific fan or pad) that allows me to use the PiSound case AND manage heat better, I would really appreciate it! The ideal outcome for me is getting to use Zynthian without the thermometer/heat warning and related throttling.
In my experience I could not install the standoff on the corner of the pi where the fan sits. I just chose to leave it off and have not had any issues.
Is that what you’re experiencing as well or are you having a different issue? Would be interesting and helpful to see pics of the problem too. I’m sure we can figure out a solution.
I am waiting for a pack of various standoffs and washers to arrive in the mail, then I will try again and post pictures, thank you! Like you @jtemple967 I did not install the standoff in the corner. My issue is…the black casing of the Audio In and Out of the PiSound rests on top of the fan, and then the fan can’t spin.
