I have just acquired a Pi 4 and I am pleased to say that the PiSound hat works fine with it.
My question is, will you be able to produce a replacement side panel for your PiSound case to accommodate the new PSU and two micro hdmi ports? The swapping of the usb and ethernet positions is easily accommodated by simply turning the end panel round. (well done in getting your tolerances spot on!). If possible and you could sell the replacement side panel separately from buying a whole new case that would be appreciated.
Also it is good that you already have an extended space between the Pi and the PiSound board, so I donāt expect there to be issues of overheating from the new Pi where the processor chip runs quite hot.
Thanks for the info @rbn I was just wondering if Pisound would work on the new Rpi!
BTW, did u use the new Raspbian Buster with it?
@rbn thanks for reporting your success with the new model. Only today we received the new version ourselves and will be doing the tests in coming days.
Regarding the Pisound enclosure - yes, we will introduce an āupgrade kitā for a fixed period of time and later on we will probably offer an universal enclosure consisting of two side panels for both Raspberry Pi layouts.
You guys are lucky. I have contacted distributor here in China and we still need to wait another 3 months to get one.
I think the RT kernel for raspberry pi 4 will not be abatible in the near future⦠the best way to get Patchbox OS and Pisound working in a Raspberry pi 4 is building an image for non real time linux.
Yes I used Raspbian Buster
One problem I have found with the PiSound card when plugged into a Pi4. It seems to disable rebooting of the Pi. If I do sudo reboot now it merely shuts down. Also in that case I have to disconnect the power supply and wait quite a time (around 30 secs) before I can plug it in a start the Pi4 again. Without the PiSound board plugged in to reboots normally. Other than that the hardware Works OK. I havenāt tested the button and other PiSound software install as I use the board mainly with Sonic Pi which I have built for source for the Pi4.
When looking at the new side panels for the PiSound case suitable for a Pi4, you may be interested to know that the Pimoroni FanShim just fits OK below a PiSound board plugged into the Pi4. having used the Pi4 quite a bit now I think it would be highly advisable to include such a fan to keep the temperature down. The only modification I had to do was to remove one of the supporting pillars because it wouldnāt fit because of the shim. A lightly shorter pilllar might be beneficial for this.
The photo shows the corner in question. I put a nut on the bottom screw which just went through the hole on the fan shim, but a shorter pillar between the top of tehe case and the shim would be helpful.
Thanks for sharing this! Have you tried the updated firmware? https://www.tomshardware.com/news/raspberry-pi-4-firmware-update-tested,39791.html
I had a look at the post and at the discussion on the Raspberry Pi Forum on this, and decided not to try it at present as it has had some issues with usb performance for some. At preeent I am very happy with the fanwhich keeps the temp low, and even with a heaving compiliation taking place on the computer, with the PiSound board in place keeps it below around 48degrees. Previously it was up in the 70s!, but
I will of course take it onboard when it becomes mainstream. Idling it is around 44degrees with the fan.
Regarding the Pi 4 reboot issue with Pisound, the issue seems to be a change of how the 3.3V supply on the GPIO header of Raspberry Pi 4 works - it now gets turned on with a 60ms delay, while 5V supply is available immediately, and during shutdown and reboot it gets turned off. 3.3V power supply on earlier Rasbperry Pi models was getting turned on nearly instantly.
Thereās a temporary workaround available, consisting of 2 parts:
Firmware EEPROM config update:
Download the bootloader from https://www.raspberrypi.org/downloads/
After extracting it, modify the config inside
pieeprom.binusing this command:sed -i -e "s/WAKE_ON_GPIO=0/WAKE_ON_GPIO=1/" pieeprom.binWAKE_ON_GPIO=1 will be the new default config value for RPi4, and eventually some update package will be released by Raspberry Pi developers.
Move all of the extracted contents to an empty FAT-formatted SD card and insert it into your Raspberry Pi 4.
Connect the power and wait for the green LED to flash quickly.
Done, now you can power off and put in an SD card with OS.
Kernel command line update (must be done everytime you flash the SD card):
- Add
sdhci.debug_quirks2=4to the end of/boot/cmdline.txt - Reboot. Then the next time you reboot, this config should be take into account, RPi4 should not get stuck anymore.
- Add
The sdhci.debug_quirks2=4 disables ā1.8Vā mode for SD card, so that makes UHS SD cards to be used at lower speeds, but this config also prevents power being cut off on the GPIOās 3.3V supply, avoiding the reboot issue.
We are still working on some proper solution for the issue, but in the mean time, we recommend everyone using Raspberry Pi 4 with Pisound to apply the workaround steps.
I found my way to these pages as I thought it might be time to go back to the Pi ⦠my original B model is in a dusty drawer at the moment. Like RBN I have become aware that there are teething problems with the RPi4 itās usb-c, PatchOS, cases, etc ⦠I my reading suggests that a cooling fan would be prudent too ⦠so I think waiting a month or so and then maybe thatāll be a good time to be a 2nd-wave adopterā¦
Some gratitude for posting these steps, Giedrius.
Just went down a multi day adventure of trying to fix the sudo reboot hanging problem, which I posted here, only to find it only happened with the pisound HAT.
Your steps fixed my sudo reboot freezing issue.
Iām running Sep10/2019 bootloader with sdhci.debug_quirks2=4 in cmdline.txt
So, with the above fix (thanks!)ā¦
ā¦While I can sudo reboot just fine, If I pull the power cord out, I have to wait >10sec or so, otherwise the unit wont bootā¦. This will be a problem to users of my device because it is very confusing when they power off to reset the device, they expect to be able to turn the power back on and have the thing reset and operating again.
Running āBuster-Liteā on Raspberry Pi 4b
My /boot/cmdline.txt:
dwc_otg.lpm_enable=0 console=serial0,115200 console=tty1 root=PARTUUID=6c586e13-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait noswap ro fastboot sdhci.debug_quirks2=4
And the bootloader seems to have WAKE_ON_GPIO=1 in the Sept 10 2019, official download, so I think itās the right version hereā¦
$ rpi-eeprom-update
Bootloader EEPROM is up to date
CURRENT: Tue 10 Sep 2019 10:41:50 AM UTC (1568112110)
LATEST: Tue 10 Sep 2019 10:41:50 AM UTC (1568112110)
opening both the downloaded pieeprom-2019-09-10.bin and the /lib/firmware/raspberrypi/bootloader/critical/pieeprom-2019-09-10.bin I see
BOOT_UART=0
WAKE_ON_GPIO=1
POWER_OFF_ON_HALT=0
FREEZE_VERSION=0
I am enjoying the processor speed for my softsynth and donāt want to downgrade
What are the plans for pisound to support Raspberry Pi 4? I see above that you thought there was a timing issue. Could the pisound firmware compensate for the timing issue? Could we fix the waiting with a hardware hack?
Any news?
Unfortunately thereās nothing we can do from our software side, as the 3.3V power supply cut happens entirely outside of Pisoundās software control reach. The state when thereās 5V supply line on, and 3.3V line is off is an invalid one for Pisoundās DAC and ADC ICs (they are dual supply and use power from both lines), the behavior of the ICs under these circumstances is not even documented, but what we could determine is that when the DAC and ADC ICs reach their regular working temperature during normal operating conditions, and 3.3V power line is switched off (after reboot or quickly unplugging and plugging in back the power supply, triggering the boot up procedure of Raspberry Pi), the ICs start back-powering the 3.3V line. On booting up, Raspberry Piās Power Management IC first attempts to discharge the 3.3V line before switching it on. As it is being back-powered via the 5V line, the 3.3V line as seen by the PMIC never gets close enough to 0V, so it does not continue to switch on the 3.3V line, getting stuck in this bad state.
Such power supply line change in Raspberry Pi 4, where 3.3V line takes 60ms instead of ~6ms, and has discharge logic, is really a big thing that add-on board designers must keep in mind and take special care of. The RPi4 should have used a fixed 3.3V regulator for the GPIO 3.3V line, or alternatively keep the 5V off in the GPIO header while the 3.3V line is off and turn both of them on at the same time.
A hardware hack would require cutting traces and would not be elegant in any way, so we canāt recommend it.
The next batch of Pisounds will have a hardware compatibility workaround implemented so it will work just fine with RPi4.
Any hacks (clean or ugly) I could do to my pisound to bring it to the level of the future PiSounds youāre planning? (Maybe later once a design is finalized). Happy with the soldering iron ![]()
Thank you for the details! Wonder if a pulldown resistor could discharge it faster (under the 60ms). But probably involve cutting traces - Iām fine doing that if it fixes me ![]()
Sure. But, Would love to get my $100 investment working on Rpi4⦠And Iām adept with soldering, have lots of experience designing as well as building circuits, as well as modding equipment by cutting traces. May I take the non-recommended route? ![]()
The change we plan to go forward with for the next revision of Pisound is to add transistors to keep the 5V GPIO supply line off while 3.3V is off, this way no backpowering when 5V is on and 3.3V is off is possible.
Hey, Iām waiting to buy a Pisound to use with a RPi 4 for a project of mine.
Iāve read in another thread that you expect it to be back in stock in February/March 2020.
Will this be the new revision with the power supply fix ? Or will these come later ?
Thank you
Yes it will be the new version - itās in production now.
