In my daily use of the midihub I recogniced that I am missing the possibility to build groups like an ARP Group or a Filter Group.
Is it possible to implement this?
Please explain a bit more about this, is it just linking together visually a couple of rows? Or something more elaborate?
If you set a lot of pipelines as in my case I have a lot of stuff here (5 volcas, MicroFreak, Circuit ā¦and so on) you really quickly lose track on what you allready did. So if I finshed my ARP pipeline I want to stick it into an ⦠maybe Box or a frame that I click off an on with a + or something ⦠if I click it off the Frames closes and I only see the Note that there is my ARP Pipeline ⦠If I want to see whats inside I can click the + again and it opens.
What about a minimize / maximize Function for that Pipeline ā¦
In the example @Keyman posted - I would want to the ability to save the pipes from āRANGE FLTRā to āHARMONā as a pipeline group named something like 'RANGED HARMONY" and for that pipeline group to be available in the editor under a section named āPipeline Groupsā or āCustom Pipesā.
aside from easy reuse from patch to patch, pipeline groups would also be great for abstraction and sharing among the community.
