ORAC - User Modules not being picked up [solved]
I put some new modules from patchbay into this folder (also tried without the final synth), restarted ORAC but they were not getting picked up in the remote Pd client. I also tried editing the preset json and hard-coded varies attempts but that didn’t work either.
/home/patch/media/orac/usermodules/synth
I had to put them in the system folder, which is a workaround but not I’m guessing how it should operate.
Any ideas?
/usr/local/orac/modules/synth
See my reply here: Orac 2.0 for the Raspberry PI
We’ll get the package itself fixed up, so this issue won’t occur again, but in the meantime, you can use the workaround.
Perfect, thank you.
