MODEP not showing any pedals
I just finished installing Patchbox OS and activated MODEP on a RPi4.
When I load up MODEP in my browser, there aren’t any plugins:
modep blank
Is there something else I need to do for the default plugins to show up?
Read this post
Thanks for your reply.
I read through the post and followed the steps mentioned by Giedrius, but it didn’t seem to change anything. Still seeing zero plugins.
You mentioned you had an error during the cp command. This is what showed for me:
modep2
Is this what you had? Any advice you can give me would be great.
Hi amatt,
Not at home now but if I remember correctly cp -r did the trick
Perfect, that did it. Thanks for your help!
Is there any reason we can’t just symlink /var/modep/lv2 to /usr/modep/lv2? Or even /var/modep to /usr/modep?
The latest plugins now come from Patchstorage. Also it’s better to copy over the old plugin releases rather than symlinking them, to avoid unexpected issues on your system when installing or upgrading MODEP via APT.
