Jack configuration with patchbox os
When configuring jack with patchbox command line tools, it seems that -S and -s option are activated.
According to doc
-S, --shorts
Try to configure card for 16-bit samples first, only trying 32-bits if unsuccessful. Default is to prefer 32-bit samples.
-s, --softmode
Ignore xruns reported by the ALSA driver. This makes JACK less likely to disconnect unresponsive ports when running without –realtime.
Is my 24 bits PiSound Card downgraded to 16 bits as a defaut behaviour ?
You may edit /etc/jackdrc using a text editor:
sudo nano /etc/jackdrc
to customize the jackd settings, then restart the server:
sudo systemctl restart jack
You can verify the audio mode by checking the Jack system logs:
journalctl -u jack
Hit the End key to go to the latest entries. If I remember right, it should log what audio settings it is currently using.
